DRAFT help
Publication date: 01/13/2026
Assignment Functions
In the JMP Formula Editor, Assignment functions work in place. That is, the result that is returned by the operation (on the right side of the operator) is stored in the argument on the left side of the operator and replaces its current value.
Assignment statements are most often used in conjunction with other commands to build a JSL script. You can use the Formula Editor to create and execute a script in that column, but this is not recommended because of dependencies and ambiguities that can result. Most often, scripts are stored as .jsl files and can be saved with a data table. See “Create and Save Scripts in Data Tables”. For more information about syntax, see “Assignment Functions” in the JSL Syntax Reference.
Note: The first argument of an Assignment function must be capable of being assigned. This means that you cannot have an assignment such as 3+=4, because 3 is a constant value that cannot be reassigned. You must first create a variable (a table variable or local variable) whose value is 3. (For more information about table variables, see “Use Data Table Variables”. For more information about local variables, see “Refer to Data Table Values in Formulas”). Then use that variable as the left-hand argument of the assignment function.
= (assign)
Puts the value of b into a. For example, (a=b).
+= (add to)
Adds the value of b to a and puts the result back into a. For example, a+=b.
-= (subtract to)
Subtracts the value of b and puts the result back into a. For example, a–=b.
*= (multiply to)
Multiplies b with a and puts the result back into a. For example, a*=b.
/= (divide to)
Divides b into a and puts the result back into a. For example, a/=b.
++ (post increment)
Adds one (1) to a, in place, so that a++. For example, if the initial value of a is 4, then the expression a++ changes a to 5.
-- (post decrement)
Subtracts one (1) from a, in place, so that a– –. For example, if the initial value of a is 4, then the expression a– – changes a to 3.
