DRAFT help
Reliability and Survival Methods > Destructive Degradation > Destructive Degradation Platform Options
Publication date: 01/13/2026
In the Destructive Degradation platform, the Degradation Data Analysis red triangle menu contains the following options:
Graph Options
Provides options for modifying the platform graphs.
Shade
Turns the shading on or off. By default, the upper and lower bounds of each shaded band at a given value of time correspond to the 0.025 and 0.975 quantiles of the distribution of Y.
Shade Coverage
If shading is on, you can enter a proportion to increase or decrease the amount of shading coverage.
See “Local Data Filters in JMP Reports”, “Redo Menus in JMP Reports”, “Group Platform”, and “Save Script Menus in JMP Reports” in Using JMP for more information about the following options:
Local Data Filter
Redo
Platform Preferences
Save Script
