DRAFT help
Using JMP > Platform Presets > Platform Presets Menu
Publication date: 01/13/2026
The Platform Presets menu is available in most platforms by clicking the Platform Presets button Image shown here on the right side of the menu bar. See also, Platforms That Do Not Support Presets.
Recently Used Platform Presets
The last five recently used presets for the current platform are listed. Presets that are not compatible with the current platform are not listed. A black dot to the left of a preset indicates that it is the last-applied preset for that report. An asterisk to the right of the preset indicates that the report has been altered since the preset was applied.
Platform Launch
Reverts the platform to the initial launch state before a preset was applied. An asterisk on the right indicates that the report has been changed from the launch state.
My Presets
Your saved presets. Only the presets that are appropriate to the current report are displayed.
Sample Presets
A variety of sample presets that are relevant to the current platform.
Save Preset As
Saves the current platform settings as a new Platform Preset or updates an existing Platform Preset. See Save Presets.
Customize Menu
Configures and groups the presets. See Customize the Presets Menus.
Copy Settings
Copies the settings of the current platform. See Copy and Paste Preset Settings.
Paste Settings
Applies the copied settings to the current platform (if compatible). See Copy and Paste Preset Settings.
Broadcasting
Just like other actions in JMP, if you press Ctrl (or Command on Apple macOS) before applying a Platform Preset, that preset is applied to all the compatible platforms in the same window.
