DRAFT help
Publication date: 01/13/2026
View Formulas in JSL
You have the option of entering or changing any part of a formula in text mode. Text mode displays the formula in JSL.The entire formula (or any of its terms) appears in the Script Editor when you double-click the formula. If the formula is long, it opens in a maximized Script Editor window. Otherwise, you can click the Maximize editor button Image shown here to maximize the window.
You can display and edit any element of a formula in the Script Editor. After editing the formula in the Script Editor, click outside the formula (or click OK in the maximized window) to see its formatted form and to save the change. To enter an If statement in text form, add pairs of arguments for each If/Then clause in the statement and a single last argument for the else clause if needed. In text form, the If statement in Figure 7.17 looks like this: If(:total!=0, (:count/:total)*100, 0).
Figure 7.17 An If Statement in Formula ModeĀ
