This is the JMP Live 19.5 help. Other versions include 19.1, 19.0, 18.2, 18.1, 18.0, 17.2, 17.1 and 17.0.
JMP Live Help
Create visualizations with your data in JMP and share your analyses or data as posts in JMP Live. Anyone viewing these posts can use the interactive features of JMP to explore your data.
Find out more about JMP Live topics.
Publish JMP Content
Create your reports in JMP and publish them as posts in a JMP Live space. You can also publish data tables directly to JMP Live.
(JMP Live only, one time setup) Add a server connection from JMP to JMP Live. Select File > Publish > Manage Connections to get started.
Create your report in JMP, or open a data table.
Select File > Publish and choose an option to get started.
For details, see “Publish Reports to JMP Live” in the JMP Online Help.
Space and folder access determine how people can interact with your content.
About JMP Live
In JMP Live, all content is contained in a space.
You can open content from any of these locations:
Home contains all posts in spaces and folders that you have permission to access. You can narrow your focus to see only:
Posts that you have recently viewed or bookmarked
Posts that contain control chart warnings assigned to you (if any)
Posts that have recently been updated
Spaces contains the spaces that you are a member of.
Figure 1.1 Post Summary in a Space and Folder (Grid Format)
Note: You can show post summaries as a grid or a list. See Change the Summary Format.
On the post summary, you see the title, when the post was last updated, the space the post is in, the user who published the post, how many views or comments the post has, and more.
Click a post summary to open it.
JMP Live Spaces
In JMP Live, all posts and folders are contained in a space.
When you first sign in to JMP Live, you might have several spaces, including a personal space (if enabled by JMP Live administrators) that you can publish to.
Tip: To quickly access your personal space, click your user icon > My personal space. If you do not have a personal space, you can create one from your account settings if this option is enabled by JMP Live administrators.
The posts and folders that you see depend on which spaces you have permission to access, either individually or indirectly through a group membership (which is controlled by JMP Live administrators).
A JMP Live administrator or JMP Live user with administrative permission on all the spaces in JMP Live creates the spaces.
The permissions that you have in the space or folder control what you can do in the space or folder. See Types of Space Permissions.
A JMP Live administrator or JMP Live user with administrative permission to a space controls the space permissions. See Update Users or Permissions.
Find out what you can do in JMP Live spaces.
Create or Delete a Space
If you have administrative permission on all spaces in JMP Live, you see an Admin page where you can create or delete spaces.
Create a Space
Click Admin > Spaces Image shown here.
Click to create a space. Give the space a name, a unique space key, and an (optional) description. See About Space Keys.
Click Save.
At the bottom, you can add users and groups to the space.
About Space Keys
Space keys have the following characteristics:
Are unique identifiers for a space
Appear in the URL of the space
Can contain only letters and numbers
Can be used to identify the space to publish to when using JMP Scripting Language (JSL)
When editing a space key, remember that URLs and JSL scripting use space keys, so any update might cause issues in scripts and with stored links.
Delete a Space
Deleting a space permanently deletes all posts within the space.
Click Delete Space.
In spaces where you have administrative access, you can update users or their permissions to access content.
Access permissions, add, or delete users
Click Spaces and then click a space on the Space Directory page.
The Posts Image shown here page opens.
Click the space name or a folder in a space.
Permissions on folders are inherited from the parent item (folder or space) unless you set custom permissions. See Set Custom Permissions on a Folder.
Click the Permissions tab.
Tip: If you do not see Permissions, you do not have administrative access to the space or folder. To request administrative access, contact an administrator listed on the About Image shown here page for the space.
(Optional) To add users or groups to a space, enter the new group or user and click Add.
(Optional) To change permissions, select or deselect permissions. Or click Select All or Deselect All.
Note: View permission is a minimum requirement for any user or group and is not removable.
6.
(Optional) To remove a user or group from a space, click Remove Image shown here.
Note: Removing a user or group removes their permission to the space and its folders. However, if a user or group is part of another group that has permission to access folders in the space, they retain that permission.
View
User can view posts in the space or folder.
Download
User can download data tables and scripts or can download posts or entire folders as JMP Projects in the space. User can also download information about control chart warnings in posts.
Contribute
User can publish new posts and edit, replace, or delete posts in the space or folder. User can also create folders.
Data Admin
User can manage data tables (update, upload, refresh, assign credentials, create an import script, or set a refresh schedule) in the space or folder.
Data Entry
User can upload data for import that is not in a JMP format to JMP Live. During the import process, the data is converted into a JMP data table. Before a user can import data, a Data Admin must set the update method and create a script. See Create an Import Script.
User can also edit data directly in JMP Live. See Upload a JMP Data Table.
Space Admin
User has administrative permission to the space. User can manage members or groups in the space by adding or removing them or changing their permissions. User can also view activity in the space.
Folder Admin
User can add or remove members or groups and change their permissions in the folder.
See Users or Manage Groups
If you have administrative permission on all spaces in JMP Live, you see an Admin page where you can see users and manage groups.
To see all JMP Live users, click Admin > Users .
To see and manage all JMP Live groups, click Admin > Groups Image shown here.
Click a group on the left side to see details for that group. You can search for a group by entering a group name or part of a group description in the Find group box.
For each group, you see the group name, description, and the group members. You can do any of these actions to a group:
Edit the group name or description (not applicable for Active Directory groups)
Enable or disable notifications for control chart warnings
Delete the group
Find members
Add or remove members (not applicable for Active Directory groups)
Create a New Group
Click Admin > Groups Image shown here.
Click Image shown here to create a new group.
Enter the group name.
(Optional) Do any of the following actions:
Enter a description.
Choose whether to send notifications for control chart warnings.
Add users to the group.
Add groups to the group.
Click Create.
Open Content in a Space
You can open folders or posts in spaces where you have View permission.
In a space, click Posts Image shown here, and then:
Click a folder to open it.
Click the Reports tab to see all reports in the folder or space. Click a post to open it.
Click the Files tab to see all posts and any subfolders in the folder or space. Click a post or folder to open it.
For more details, see Open a Post.
Add Folders to a Space
You can add any number and level of folders to spaces where you have Contribute permission.
In a space, click Posts Image shown here.
Create a folder in either of these ways:
Right-click on the space or a folder and then select Create folder.
At the top, click Image shown here > Folder.
Add a title.
(Optional) Add a description.
Click Create.
Notes:
Folder permissions are inherited from the space unless you set custom permissions on the folder. See Set Custom Permissions on a Folder.
Folders in spaces are sorted alphabetically ascending by title.
Update Details for a Folder
You can update the title, description, or image thumbnail for folders where you have Contribute permission.
See a folder’s details in either of these ways:
Right-click on the space or a folder and then select Details.
Click a folder. At the upper right, click Image shown here.
To change the title or description:
a.
Click Image shown here to edit the folder details.
b.
Enter your text.
c.
Click Save.
To change the image thumbnail:
a.
Hover over the thumbnail and click Change Thumbnail.
b.
Select an image on your computer and click Open.
Move a Folder
You can move any folder for which you have Contribute permission. You can move folders within spaces, but not between spaces.
Move a folder in either of these ways:
Right-click on the space or a folder and then select Move folder.
Click a folder. At the top, click Image shown here > Move folder.
Choose the space that you want to move the folder to.
Tip: You can choose a folder in the destination space to nest the folder under or create a new folder by clicking the Create folder Image shown here icon.
Click Move.
Change the Owner of a Folder
Changing a folder’s owner requires Contribute or Space Admin permission to the folder or space the folder is in.
From a folder, click Image shown here > Change owner. Or, from the Details panel, click Image shown here.
Click New owner and then select the new owner.
Click Reassign.
You can set custom permissions on folders where you have Folder Admin permission.
From a space, click Posts Image shown here.
Click a folder.
Click Permissions.
Tip: If you do not see Permissions, you do not have Folder Admin permission. To request permission, contact an administrator on the About Image shown here page for the space.
Click Apply Custom Permissions.
You can do any of the following:
Remove access
Next to a user or group, click Remove Image shown here.
Note: Removing a user or group removes their permission to the folder and any subfolders. However, if a user or group is part of another group that has permission to access the folder, they retain that permission.
Change access
Next to a user or group, update the access permissions.
You can change access permissions for a member of a group that has access to the folder. For example, you might have a group that has permission to view the folder, but you want to give an individual group member permission to contribute to the folder. In the Add users and groups field, enter the member’s user name and click Add, and then update their individual permissions.
Note: You cannot grant permission to a subfolder unless the user or group has at least View permission to the parent folder.
(Optional) To remove custom permissions and revert to the parent folder or space permissions, click Remove Custom Permissions.
Delete Folders
Delete folders in either of these ways:
Right-click a folder and then select Delete.
Click Files. Select the folders that you want to delete and then click Image shown here.
Click Confirm.
See Details About a Space
For spaces that you have access to, you see details, such as a description of the space, the space key (for scripting), the space administrators, and attributes.
In a space, click About Image shown here.
Figure 1.2 Details About a Space
Note: Only space administrators can edit details or delete spaces.
Change the Owner of a Space
You can change the owner of the root folder of a space. No folders or posts within the space are changed.
Changing the owner of the root folder of a space requires Contribute or Space Admin permission to the folder or space the folder is in.
From a space, click Image shown here > Change owner. Or, from the Details panel, click Image shown here.
Click Reassign.
See Control Chart Warnings in a Space
You can see posts with active control chart warnings in a space:
In a space, click Warnings Image shown here from the left panel. If there is no warning circle next to the icon, there are no active warnings in the space.
In the Active Warnings window, click Image shown here a post summary to open details.
For more details, see Control Chart Warnings in Graphs.
See the History of a Space
For spaces where you have administrative access, you can see the history of the space and any folders in the space, which includes access changes and changes to posts.
Click History Image shown here in a space or a post.
You can browse all history or limit your search using the filters.
Figure 1.3 Filter Options in History
In the filters, enter any combination of dates, actions, users, and whether the action succeeded or failed.
(Optional) To access log details:
Next to an action, click Image shown here to see log information or updated attributes.
In the upper right, click Image shown here to download the audit log.
See Activity in a Space
For spaces where you have administrative access, you can see who has viewed and downloaded posts in the space.
In a space, click Views Image shown here.
You can browse all history or limit your search using filters.
In the filters, enter any combination of users, access types, and dates.
(Optional) To download the activity records for the space, click Image shown here
Favorite a Space
To quickly find spaces that you have access to, you can favorite them:
From the Home page or Space Directory, hover over a space and click Image shown here.
In a space, click About, and then click Favorite.
Tip: You can unfavorite a space in the same way.
Once you favorite a space, it appears at the top of the list in these areas:
Under Spaces at left on the Home page
Under the Spaces menu in the title bar
Figure 1.4 Favorites in the Home Page and Spaces menu
Clean Up Spaces
For spaces where you have administrative access, click Cleanup Image shown here or click Admin > Cleanup Image shown here to do any of the following actions:
Clean Up Empty Spaces
Use filters to narrow your search.
Figure 1.5 Filters to Find Empty Spaces
Narrow results by using any combination of keywords in space titles and the space type (normal or personal).
To delete spaces:
Select the spaces that you want to delete.
To select all, check the box next to Title.
Click Confirm.
Clean Up Empty Folders
Figure 1.6 Filters to Find Empty Folders
Narrow results by using any combination of keywords in folder titles, spaces, users, and date ranges for when the folder was emptied.
(Optional) To see folder details and other options, click Image shown here and choose an option.
To delete folders:
Select the folders that you want to delete.
Click Confirm.
Clean Up Outdated Report Posts
Figure 1.7 Filters to Find Outdated Report Posts
Narrow results by using any combination of keywords in report titles, spaces, users, and cutoff dates for reports last modified or accessed before that date.
Tip: By default, report posts last accessed more than 30 days ago are included.
(Optional) To see report post details and other options, next to a report post, click Image shown here and choose an option.
To delete report posts:
Select the report posts that you want to delete.
Click Confirm.
Clean Up Unused Data Posts
Figure 1.8 Filters to Find Unused Data Posts
Narrow results by using any combination of keywords in data table titles, spaces, and update methods (if applicable).
(Optional) To see details about a data post or copy the ID or path to the data post, click Image shown here and choose an option.
To delete data posts:
Select the data posts that you want to delete.
Click Confirm.
JMP Live Posts
Find out what you can do with JMP Live posts.
Tip: See also JMP Live Data.
Open a Post
You can open posts in places where you have View permission.
To open a post from the Home page, click it.
To open a report or a data post from a space:
Click Posts Image shown here from the left panel.
Click a folder.
Click a post in the Reports tab. To open a data post, click the Files tab and click a data post.
Figure 1.9 Post in a Space and Folder
Depending on your permissions, in addition to seeing details, adding comments, viewing the history, and seeing who has viewed the data, you can:
View, edit, copy, or download the JSL script that creates the post.
Access or change the data associated with the post.
Assign add-ins to a post.
Open a Post in JMP
You must have Download permission to the post and a JMP Live connection set up in JMP.
From a post, click Image shown here to open the content in JMP. The content is downloaded to your machine and opens in JMP as a JMP Project. See Download Posts as JMP Projects.
See All of Your Posts
To see all of your reports, click your user icon > Profile > Reports Image shown here.
To see all of your data posts, click your user icon > Profile > Data Image shown here.
Update Post Details
You can update the title, thumbnail image, description, or settings for JMP Live posts. Updating a post’s details requires Contribute permission.
From a post, click Image shown here. From a post summary, click Image shown here > Details.
Next to the section that you want to update, click Image shown here.
Tip: In the post description, you can use these HTML tags: <a href= "target">, <b>, <em>, <i>, <strong>, and <u>.
To change the thumbnail image, hover over the thumbnail and click Change Thumbnail.
Figure 1.10 Update a Post’s Details
Move a Post
You can move a post to a different folder in the same space or to a folder in a different space. Moving posts requires Contribute permission in both the original location and the new location.
Tip: For help with permissions, contact the space administrator. To find out who the space administrator is, click About Image shown here in a space.
To move a single post in a space, click Image shown here > Move post. However, if you want to also move the data associated with the post, see Move multiple posts at once.
Figure 1.11 Move a Post
Move a Post
Go to the folder that contains the posts that you want to move.
Click the Files tab.
Select the posts that you want to move.
Click Image shown here to move the selected items.
6.
Choose the space (and folder, if applicable) to move the posts to. You can also create a new folder Image shown here in the destination space.
7.
Click Move.
Tip: See also Move a Folder.
Comment on a Post
You can see or add comments to JMP Live posts or folders. Viewing and adding comments requires View permission.
In a post or folder, click Image shown here.
Enter a comment or reply to an existing comment.
(Optional) Type @ and choose a user’s name to mention them.
Click Submit.
Tips:
To edit or delete your comments, click Image shown here > Edit or Delete.
To delete all comments on a post that you own, next to the number of comments, click Image shown here > Delete all.
To format text, you can use keyboard shortcuts (such as Ctrl+B for bold or Ctrl+I for italics) or you can use markdown syntax.
To add a link to a comment, copy and paste the link or enter the URL in the comment box.
To see how many user comments are on a post, in a post summary, a number appears beside the Comments icon Image shown here.
By default, you get a notification in the following situations:
If someone adds or replies to a comment on a post that you own
If someone @ mentions you in a comment
If someone replies to a comment that you made
If someone deletes a comment that you made
Share a Post
In a post, click Image shown here > Share to share the post by copying a link. For report posts, you can also copy the embedded HTML code. The post is shared as it was published or regenerated and does not include any changes made while viewing it.
Bookmark a Post or Folder
In a post or folder, click Image shown here to bookmark the post or folder.
To see all of your bookmarked posts and folders, at the upper right, click the Bookmarks Image shown here icon.
To remove a bookmark, click Image shown here to unbookmark a post or folder.
Figure 1.12 Example of the Bookmarks Page
Delete a Post
You can delete posts or folders where you have Contribute permission.
Note: You cannot delete a data post if a JMP Live post is using the data.
To delete a single JMP Live post or a folder from a post, space, or post summary, click Image shown here > Delete post.
If the data associated with a report post is no longer used by any reports, you are prompted to delete the data.
Figure 1.13 Delete a Post
Delete a Post
Delete several posts or folders
Go to the folder that contains the posts or folders that you want to delete.
Select the posts that you want to delete.
Click Image shown here to delete the selected posts.
6.
Click Confirm.
Duplicate a Post
You can duplicate one or more data or report posts on JMP Live.
To duplicate a post, you need View and Download permission to the source folder and Contribute permission to the destination folder.
Duplicate a single post
From a post or a post thumbnail, click Image shown here and then select Duplicate post.
Select the destination space and folder.
(Optional) If the report post contains control chart warnings, you can copy them to the duplicate post.
Click Duplicate.
Duplicate multiple posts
In a space, click the Reports tab (to duplicate only report posts) or the Files tab (to duplicate data posts and report posts).
Select the posts that you want to duplicate.
At the top, click Image shown here.
6.
Click Duplicate.
Notes:
When duplicating a report post to the same space, the copied report is connected to the original data post.
When duplicating a report post to a different space, the data post is copied to the destination space.
Whoever duplicates the post becomes the owner of the duplicated post. For example, if the original post is created by User X, and User Y duplicates it, User Y becomes the owner of the duplicated post.
Add-ins and credentials assigned to the original post remain in the duplicate post as long as the credentials have been shared with the new owner.
Create a Report Post
If you have a JSL script that creates a JMP report, you can use the script to create the report post directly from JMP Live.
You can create a report post from a folder or space where you have Contribute permission.
From a space or a folder, click Image shown here and then select Report.
Enter a title.
(Optional) Enter a description.
Click Create.
In the Script panel:
Under Report script, paste your JSL script.
Click Save.
Under Data tables, click Add.
Click Select new data and select the data table referenced in your JSL script.
Tip: If you do not see your data table, you need to add it to JMP Live. See Create a Data Post.
Figure 1.14 Example of Report Script and Data Table
Click Save.
If you want to open several files from JMP Live in JMP, download the post and any related content (such as data) as a JMP project file. A project file keeps all of the post’s content in one tabbed window in JMP. Content that is associated with a post can include data tables, scripts, maps, or images.
You can download posts or folders that you published or where you have Download permission.
Download a folder or post as a JMP project file
From a folder or a post, click Image shown here > Download as JMP project.
Download several posts as a JMP project file
From a space or a folder, click the Files tab.
Select the posts that you want to include in the project.
Click Image shown here to download the selected items.
Note: If you cannot access the download options, your JMP Live administrator might have disabled the downloading feature.
For details about projects, see “Work with Projects” in the JMP Online Help.
See Who Has Viewed a Post
To see who has viewed a JMP Live post that you created:
From a post, click Views Image shown here.
From a folder, at the upper right, click Image shown here > Advanced > View accesses.
You can see who accessed each post, when they accessed it, and the type of access (View or Download).
Present a Report or Image Post
To enter presenter mode from a JMP Live report or image post that you created, click Image shown here > Presenter mode at the upper right.
Presenter mode shows the currently selected JMP Live report in full-screen mode. Web browser menus and tools are removed so that the viewer can focus on the report.
In presenter mode, you can do any of the following tasks:
Move through report or image posts in a folder by using the navigation arrows
Tip: You can also use the left and right arrow keys to move between report or image posts. To jump to the first or last post, press Shift and then select the left or right arrow key.
Reposition the floating controls
Exit presenter mode
See the History of a Post
You can see the history of posts that you have access to, which includes data source changes and updates to the post.
Figure 1.15 Filter Options in History
On supported areas of the Home page or from the Spaces > Posts page, at the upper right, click an icon to change the format of JMP Live post summaries.
The grid format shows cards with image thumbnails.
The list format shows a list with image thumbnails.
The compact list format shows a list with no image thumbnails.
Sort Posts
You can sort how posts appear in places like the Home page or in a space. Click the Change sort order Image shown here icon and choose an option, such as alphabetical or newest.
Change the Owner of a Post
Changing the owner of a post requires Contribute or Space Admin permission for the folder or space that contains the post.
From a post, click Image shown here > Change owner. Or, from the Details panel, click Image shown here.
Click Reassign.
Note: If the post contains credentials that are not shared with the new owner, those credentials are removed.
See Performance Metrics on a Report Post
Select a post and click Image shown here > Advanced > Display performance metrics. You can see how long it took the post to load, copy the metrics, or clear the metrics.
Show Log Messages for a Post
In a JMP Live report post, you can click Image shown here > Display log messages to see any error messages from the server, connection messages, and messages from the client.
Copy a Post or Folder ID for Scripting
To copy a folder ID, in the left navigation, right-click a folder and then select Copy ID to clipboard.
Copy a post ID in either of these ways:
Click Files. Next to a post, click Image shown here > Copy ID to clipboard.
Click Reports. On a post, click Image shown here > Copy ID to clipboard.
Edit a Script
In a JMP Live post, you can edit the JSL script that generates the report.
In a post, click Script.
Under Report script, edit the script using JSL.
Tip: To increase the window size, click Image shown here.
Click Save.
Click Regenerate Report.
Revert to the original script
Next to Report script, click Image shown here > View original script.
Click Image shown here to copy the script.
Click Close.
Select the entire JSL script and paste the original script.
Click Save.
6.
Use a JMP Add-In
The option that you choose depends on the type of post:
In a JMP Live report post, click Script.
In a JMP Live data post, click Settings.
Next to Add-ins, click Assign.
Note: In a JMP Live data post, this option appears only if you select the Refresh or Import update methods.
Select an add-in.
If you do not see any add-ins, your JMP Live administrator has not added them.
Click Save.
JMP Live Graphs
Find out what you can do with JMP Live graphs.
See Data Values in Graphs
In a JMP Live report post, you can see information about data points in graphs or report calculations.
Click or tap Identify Objects Image shown here.
Hover over or tap a data point or a calculation.
Figure 1.16 See a Data Point’s Values
Figure 1.17 See an Explanation of a P-Value Calculation
Tips:
To hide or show a report or graph, click or tap the arrow next to the title.
If your report contains very large tables, use the page controls Image shown here
Select Data in Graphs
In a JMP Live graph, you can select data or zoom in on data.
How you select data in a JMP graph (points, bars, and so on) depends on whether you are on a computer or a mobile device. The default mode is to select a single data point.
Task
On a Computer
On a Mobile Device
Select or deselect a single data point
Click a data point.
Tap Image shown here then tap a data point.
Select or deselect multiple data points
Press Ctrl+Shift and click multiple data points.
Tap Image shown here and then tap multiple data points.
Identify a single data point
Hover over a single data point.
Tap Image shown here and then tap a data point.
Select data points by brushing
Click and drag a rectangle over data points. Click and drag in the center to move the rectangle or drag the corners to resize it.
Tap Image shown here and then draw a rectangle over the data points. Drag the center to move the rectangle or drag the corners to resize it.
Zoom
Click Image shown here and click a point or drag a rectangle. The center of the rectangle is now the center of the zoom area.
To zoom out, double-click in the graph or press Shift and click the graph.
You can also use the scroll wheel on your mouse to zoom in and out. If you are not in Zoom mode, press Alt before zooming with the scroll wheel.
Tip: To zoom the entire window, press Ctrl then + or Ctrl then -.
Tap Image shown here and pinch zoom.
Pan in a graph
Click Image shown here and click and drag in the graph. Or press Alt and click and drag in the graph.
Tap Image shown here and move the graph with your finger.
Pan axes
Click the middle of an axis and drag.
Touch the middle of an axis and drag.
Scale axes
Click at either end of an axis and drag.
Touch either end of an axis and drag.
Return axes or graphs to their original state
Press Alt and double-click in the graph or click Image shown here or Image shown here > Reset all axes.
Double-tap in the graph or tap Image shown here > Reset all axes.
Note: In interactive HTML, some graphs do not support panning and zooming. Panning and zooming is fully supported in JMP Live and JMP Public.
See Linked Data in Graphs
If your JMP Live post contains multiple JMP graphs, when you select data in one graph, it is highlighted in all graphs.
Figure 1.18 Select Data in Linked Graphs
A histogram bar in the top graph is selected. The corresponding rows are highlighted in the scatterplot and in the marginal histogram.
Selecting data in a graph, legend, or report can highlight the corresponding data.
Figure 1.19 Select Data in a Graph to Highlight it in a Report
A histogram bar is selected and the corresponding data are highlighted in the Frequencies report. You can also select a row in the report to highlight the corresponding data in the histogram.
Exclude and Hide Data in Graphs
After you select data in a JMP graph, you can exclude it from report calculations and hide it in graphs. Reports and graphs automatically update.
Figure 1.20 Report Menu Options
Report Menu Options
To exclude and hide data, right-click the graph or use these options in the More Image shown here menu at the upper right:
Note: If the post contains a Local Data Filter, most of these options do not appear because you use the Local Data Filter instead.
Exclude and hide selected rows
Excludes and hides selected data.
Include and show all rows
Includes and shows any excluded or hidden data.
Invert row selection
Changes the current selection to the deselected data.
Filter Data in Graphs
If the original JMP report included a Local Data Filter, you can use the filter to focus on specific data and see the impact on JMP Live graphs.
Figure 1.21 Filter Data in Graphs
Tip: Selections that you make in the Local Data Filter are captured in the URL. You can copy and paste the URL to share your selections with others.
In the Filter Data in Graphs example, the filter choices are showing only females between 51 and 63 inches tall who are between the ages of 12 and 14.
Tip: If several categories are selected and you want to select a single category, click the category (not the check box).
Local Data Filter Options
Conditional Filtering
Limits the options in the Local Data Filter by condition. For more information about conditional data filters, see “Red Triangle Options for the Data Filter” in the JMP Online Help.
Note: This option does not appear if there is more than one OR group or if the columns are not hierarchical.
Select filtered rows in graphs
Selects all filtered rows in graphs.
Show filtered rows in graphs
Shows all filtered rows in graphs.
Include filtered rows in calculations
(JMP Live and JMP Public only) Includes only filtered rows in report calculations.
Auto update
(JMP Live and JMP Public only) Enables automatic updates to the local data filter.
Inverse
Inverts currently selected filters.
Note: If your chart contains Area or Fill between options segments, you must refresh the post to see changes for the Inverse option.
Manually Update Data Filters
If a post is taking a long time to automatically update, you can manually update the data filter selections instead.
Click Auto Update to deselect this option.
Make your changes to the local data filter.
The graphs do not update as you make your changes.
Click Update.
Switch Data Columns in Graphs
If the original JMP report included a Column Switcher, you can quickly analyze different variables without re-creating the analysis. When you choose a different variable in JMP Live, the analyses automatically recalculate using the new variable.
In the following example, using Fisher’s Iris data, the JMP post includes a Column Switcher and a Local Data Filter.
Figure 1.22 Initial Selections
Initial Selections
Initially, Petal length (the original column) is selected in the Column Switcher. All species are showing in the Local Data Filter. These selections are reflected in the graph and calculations.
Figure 1.23 Updated Selections
Updated Selections
In this example, Petal width is selected in the Column Switcher, and only the species versicolor is selected in the Local Data Filter. The graph and calculations update to reflect these selections.
Tip: Selections that you make in the Local Data Filter and Column Switcher are captured in the URL. You can copy and paste the URL to share your selections with others.
JMP Live posts that contain control charts can generate notifications if there are control chart warnings. When you publish a JMP post that contains a control chart, you can specify whether to enable warnings. You can also enable warnings from a JMP Live post.
These people receive notifications:
The publisher of the post
Users who subscribe to warnings for a space, folder, or post
Members of groups where warning notifications are enabled and who have permission to view the post
Depending on individual settings, notifications appear in JMP Live and via email. Email notifications contain more detail about the warnings. See Manage Notifications.
Subscribe to warnings
In a space, folder, or post that contains control charts, click Image shown here > Subscriptions.
Click to subscribe to control chart warnings on all posts in a space, folder, or on an individual post.
See and triage warnings
In a post or from a thumbnail, click Warnings Image shown here. For details about how to triage warnings, see JMP Live for SPC at https://www.jmp.com/jmplivespc.
Enable or disable warning notifications
Enabling or disabling warnings on posts requires Contribute permission.
In a post that contains a control chart, click Warnings Image shown here.
Next to Notifications, click the switch to turn them on or off.
(Notifications on only) If the post has active warnings, choose whether to notify people about these warnings.
Customize Graphs
Note: These customizations are temporary while you are in the JMP Live post.
To resize a graph in JMP Live, click and drag on the graph borders. You can also resize a scrollable post in a JMP Live dashboard.
Use the options in the More Image shown here menu to customize graph elements.
Figure 1.24 Fit a Graph to the Window
You can increase or decrease the marker size for all graphs that include markers. For Graph Builder and Control Chart graphs, you can automatically size the graph based on your browser window size by turning on Fit to Window.
Note: The options in this menu vary depending on the type of graph or JMP platform.
JMP Live Data
Find out what you can do with data in JMP Live.
Open a Data Table
In a space or folder, click the Files tab.
Click a data post Image shown here.
Figure 1.25 Example Data Table
Example Data Table
Hide or show columns or see information for a column.
Access reports that depend on the data post.
Edit the data table. See Edit a Data Table.
Change the settings for updating the data post. See Upload a JMP Data Table, Refresh Data, and Import Data.
Assign a JMP add-in to the data post. See Use a JMP Add-In.
Add a reference to other data. See Reference a Data Table.
Tip: See also JMP Live Posts.
Edit a Data Table
Editing a data table post requires Contribute, Data Admin, or Data Entry permission.
In a report post, click Data Image shown here.
Under Data, click a data table.
At the top, click Edit.
Notes:
Only one person at a time can edit a data table. If you try to edit data that someone is already working on, a warning message appears.
You can use these keyboard shortcuts:
Arrow keys move between cells.
Enter key saves changes to a cell.
Esc key cancels changes to a cell.
Add rows to a data table
Right-click in a table and select Add rows.
Use the arrows to set how many rows you want to add.
Click OK.
Delete rows from a data table
Select the rows that you want to delete.
Right-click the rows and select Delete [number] rows.
Save your changes to a data table
To save your changes, choose an option:
Click Save to permanently save your changes. Any related reports are automatically regenerated.
To temporarily save your changes, click Save draft. The next time that you edit the data, you can restore your draft changes (or start over).
Caution: If you save a draft and someone else permanently saves edits to the table, your changes are lost.
Notes:
You cannot add or rename columns in a data table.
To see the properties for a column, click Image shown here > Column Info. You can autosize the column or all columns, or see details such as the data type, modeling type, format, and width.
Download Data or Scripts
Downloading data or scripts requires Download permission.
Download data from a post
Next to the data table title, click Image shown here > Download Image shown here.
Download data from a data table
In a data table, click Image shown here > Download data table.
Download scripts
In a report post, click Script Image shown here.
Click Image shown here to download the JSL script.
(Optional) Click Image shown here to copy a script.
Change the Data Source
You can select another source of data to use in a JMP Live post. You need Contribute permission on the report post and Download permission on the data post that you want to start using.
From the report post that you want to update, click Data Image shown here.
Next to the data table title, click Image shown here > Change data source.
Under New Data, enter the data post name or choose a data post from the list.
Create a Data Post
To create a data post directly from JMP Live, you can upload a JMP data table or use a JSL script that adds refreshable data or uploads other types of data.
You can create a data post from a folder or space where you have Contribute permission.
From a space or a folder, click Image shown here > Data table.
Enter a title.
Click Create.
Add your data by following any of these processes:
From a data post, click Settings Image shown here.
Under Update Data Settings, click Upload JMP data table.
At the top, click Upload.
Click New data table and navigate to your JMP data table file.
Click Save.
Refresh Data
In JMP Live, you can use a script to refresh data. Follow these general steps:
Create a refresh script in a data post. See Create a Refresh Script.
Create and assign any required credentials. See Add or Update Credentials and Assign Credentials.
Test the refresh script. See Refresh Data on Demand.
(Optional) Schedule the data to refresh at intervals. See Schedule a Refresh.
Tip: After you create the credentials, you can also Add or Update Credentials or See and Share Refresh Credentials.
Creating a refresh script requires Data Admin permission. Note the following additional requirements:
Your script must create and return a data table. Or you can return a value of zero to not update the underlying data table.
If your refresh script connects to a database, note the following details:
The appropriate ODBC driver must be installed on the machines that host all of the JMP sessions pools. The JMP session pool hosts also must be able to access the required data source (for example, consider firewall rules or other restrictions).
Your connection string must specify the exact server, database name, and driver.
In a refresh script, you can:
Retrieve data by connecting to a database or Web API or read files from allowed directories. The script can also build the data itself.
Reference other data tables. See Reference a Data Table.
Include JSL commands to perform actions on the data, such as recoding and so on.
Use add-ins in your script. See Use a JMP Add-In.
Create the refresh script
Click Settings Image shown here.
Select Refresh data via script as the update method.
Figure 1.26 Refresh Data Using a Script
Create the refresh script. See Examples of Refresh Scripts.
6.
Paste your refresh script under Refresh Script.
7.
Click Save.
At the upper right, click your user icon > Settings.
From the left panel, click Credentials Image shown here.
To update the credentials:
Click Image shown here to edit the credentials. Update the credential name. Click Update credential to modify the user name and password.
Click Delete Image shown here to delete a credential.
Click Image shown here to add a new credential.
Figure 1.27 Add Your Stored Credentials
Name the credential.
Tip: Use a name that helps you identify the credential, such as the name of the database.
6.
Enter a user name and password for the credential.
7.
(Optional) Upload a private key file.
Depending on your data source provider, some authentication processes require the use of a private key file.
8.
Click Save.
Assign Credentials
If any JSL commands in your refresh script require credentials to access an external server or database, you can securely add and assign those credentials. In the refresh script, your credentials are represented by generic placeholders (%_PWD_% and %_UID_%) and are not visible. When the refresh script runs, the script replaces the generic placeholders with the actual credentials.
Ensure that you have created a refresh script. See Create a Refresh Script.
Click Assign under Credentials.
Figure 1.28 Assign an Existing Credential
Click Image shown here to create a new credential. See Add or Update Credentials. Or select the credential that you want to use.
6.
(Optional) Click Set as default to make the credential available in the refresh script.
7.
Click Save.
Refreshing data requires Contribute permission.
Click Settings.
Ensure that you create and store the credentials in JMP Live if your data comes from a third party and uses credentials. See Assign Credentials.
6.
Click Refresh > Refresh.
Schedule a Refresh
Scheduling a refresh requires Data Admin permission. You can schedule data to refresh as often as every 10 seconds or as infrequently as once per week. You can also have several schedules for a data post. For example, you might have one schedule to refresh the data every Tuesday at 9 p.m., and another schedule to also refresh the data hourly every Friday from 8 a.m. until 5 p.m.
Note: Schedules are based on the time zone that your JMP Live server is in.
Click Settings.
6.
Click Create next to Refresh Schedules.
Figure 1.29 Create a Refresh Schedule
7.
Select the following details:
Time for the refresh to start.
Days of the week to run the refresh.
(Optional) To repeatedly refresh data during a time period, specify how often to repeat the refresh and what time to stop refreshing the data.
(Optional) Set a date for the refresh to expire. The expiration date is inclusive, so the refresh expires at 11:59 p.m. on the day.
8.
Click Save.
9.
Under Refresh Schedules, you can enable, edit, or delete a schedule.
You can create a refresh script using JSL or Python (if your administrator allows it).
Tip: If your data table contains a source script, you can use that script as a base (modifying it as required).
Example of a JSL Refresh Script
In this script, substitute the placeholders with your details.
dt = New SQL Query(
       Connection(
			"ODBC:DATABASE=placeholder;
			DRIVER={placeholder};
			PORT=placeholder;
			PWD=%_PWD_%;
			SERVER=placeholder;
			UID=%_UID_%;"
       QueryName( "placeholder" ),
       Select,
       From( Table( "placeholder", Schema( "placeholder" ) ) )
) << Run Foreground;
dt;
Notes:
Do not replace PWD=%_PWD_% and UID=%_UID_%. These are wildcards for your password and user name to keep them encrypted. Your assigned credentials replace these wildcards when the script is run.
The settings in the Connection string vary depending on your setup.
If your data table was created using a data connector, you might want to remove the Driver( ... ) line, if present. That driver might not be on JMP Live, and when using a built-in configuration (a line like ID( "com.jmp.PLACEHOLDER" )), JMP automatically attempts to find a suitable driver if one is not provided.
Tip: You can also use Query Builder to help create a JSL refresh script. See “Write a SQL Query” in the JMP Online Help.
Example of a Python Refresh Script
import jmp
dt = jmp.open(jmp.SAMPLE_DATA + 'Big Class.jmp')
jmp.live.set_result(dt)
Note: The jmp.live.set_result() function updates the table on JMP live with the data table from Python. Calling this function with None (jmp.live.set_result(None)) cancels the Python refresh script.
In JMP Live, you can see all of your refresh credentials and you can see any data tables that are using the credentials. At the upper right, click your user icon > Settings > Credentials Image shown here. You can also share a credential:
Next to a credential, click Image shown here.
Select the user or group that you want to share the credential with.
Click Add.
Click Close.
Import Data
Importing data requires Contribute or Data Import permission. You can import data such as a CSV or Microsoft Excel file. The file is converted into a JMP data table.
Click Import.
If the Import button is not active, a user with Data Admin permission must create the import script. See Create an Import Script.
Open the data that you want to import.
Click Reload to refresh the data.
Creating an import script requires Data Admin permission. Your import script must contain a %FILENAME% placeholder that replaces the file path. See Example of Importing Data.
In an import script, you can:
Tip: If your data table contains a source script, you can use that script as a base (modifying it as required) or start with an empty script and paste your new import script.
Create the import script
Select Import data via script as the update method.
Figure 1.30 Import Data Using a Script
Select the type of file that you want to import.
Create the import script using JSL.
Paste your import script under Import script.
6.
Click Save.
In this example, you have a CSV file with names and ages. You open the file in JMP, which converts it to a JMP data table. You publish this JMP data table to JMP Live.
The data in the CSV file can change, so you want to update the data in JMP Live by importing the latest data from the CSV file.
From the data post, click Settings Image shown here.
Select Import data via script.
Select CSV file.
Figure 1.31 Importing Data from a CSV File
(Appears only if the data table contains a source script.) Click Empty Script.
Paste a script, such as the following example.
Open(
	"%FILENAME%",
	columns(
		New Column( "Name", Character, "Nominal" ),
		New Column( "Age", Numeric, "Continuous", Format( "Best", 12 ) )
	Import Settings(
		End Of Line( CRLF, CR, LF ),
		End Of Field( Comma, CSV( 1 ) ),
		Treat Leading Zeros as Character( 1 ),
		Strip Quotes( 0 ),
		Use Apostrophe as Quotation Mark( 0 ),
		Use Regional Settings( 0 ),
		Scan Whole File( 1 ),
		Treat empty columns as numeric( 0 ),
		CompressNumericColumns( 0 ),
		CompressCharacterColumns( 0 ),
		CompressAllowListCheck( 0 ),
		Labels( 1 ),
		Column Names Start( 1 ),
		First Named Column( 1 ),
		Data Starts( 2 ),
		Lines To Read( "All" ),
		Year Rule( "20xx" )
6.
Click Save.
7.
Click Import.
8.
Open the updated CSV file on your computer.
9.
Click Import.
Figure 1.32 Updated Data from CSV File
Notice that the data is updated and includes an additional name.
Restore the Previous Version
To revert your updates back to the previous version:
At the upper right, click Image shown here > Restore previous version.
Click Restore to confirm.
Click Reload to update the data.
If you have data that depends on other data, you can add a reference to the original data. If the original data updates, the associated data updates as well. For example, if your data table in JMP Live is a summary table that you created from another data table, you would reference that table.
Click a data post.
Next to Data tables, click Add.
Note: This option appears only if you select the Refresh or Import update methods.
Select the original data table.
6.
Click Save.
Search JMP Live
To find posts, users, or spaces across JMP Live, enter a keyword in the search box. Click Posts, Users, or Spaces to see specific types of results.
Figure 1.33 Example of Searching by Keyword
Here are some actions that you can take from the search results:
Posts
To open a post, click the title or image.
To open the post author’s profile, click their user name.
To open a space or folder, click the space or folder title.
To bookmark a post, click Image shown here.
To copy the post ID for scripting, click Image shown here > Copy ID to clipboard.
To move or delete a post that you own, click Image shown here > Move post or Delete post.
Users
To open a user’s profile, click their user name.
Spaces
To open a space, click the space.
Use Filters in JMP Live Searches
You can use filters to narrow your searches in JMP Live.
Click Image shown here at the upper right (where applicable).
Enter any combination of keywords, user or space names, or dates. You can also filter by control chart warnings, and in some cases, by post type.
Click outside of the Filters panel to see the results.
Click Clear All to stop filtering.
Tips:
To filter by your own posts, click your user icon > Profile.
To search for a page or a space in JMP Live, use the keyboard shortcut Ctrl + comma and enter the name of the page or space that you are looking for.
Update Your JMP Live Settings
You can update the following items in your JMP Live settings:
Update Your Settings
Change your profile picture: Next to Avatar, click Image shown here > Upload new avatar or Reset to default.
Change your display name: Next to Display Name, click Image shown here and enter and save your new name.
Note: You might not be able to edit your display name because this action depends on your JMP Live server’s authentication settings.
Add a secondary email: Next to Secondary E-mail, click Image shown here and enter and save your email address. You can send notifications to primary or secondary emails, or both.
Figure 1.34 Update Your Settings
Verify your account details
Click your user icon and then select Settings at the upper right.
Verify your username or the email that is associated with your account.
(Local authentication method only) Verify or change your password.
Tip: To view your profile as others see it, click Image shown here.
As a JMP Live user, you can be notified about comments, changes to posts, changes to your access settings, control chart warnings, and more, depending on your notification settings.
Open or Act on Notifications
To see your notifications, click Image shown here. From here, you can perform the following actions:
To open the source, such as a post, click a notification.
To clear a notification, click Image shown here > Clear notification.
To stop receiving notifications of a certain type, click Image shown here > Stop receiving <type> notifications.
To mark all notifications as read, click Image shown here.
To remove all notifications, click Image shown here.
To change your notification settings, click Image shown here. See Change Notification Settings.
To see all notifications in a larger window, click See All.
Access your notification settings in either of these ways:
At the upper right, click your user icon > Settings. On the left side, click Notifications Image shown here.
Click Notifications Image shown here > Image shown here.
On the Notification Settings page, you can enable or disable notifications. If you enable a notification, choose how often you want to receive email notifications.
Figure 1.35 Notification Settings
Notes:
If a secondary email address is set up, you can choose which account to send notifications to (primary, secondary, or both).
To sort notifications by ascending or descending order, click the arrow next to the Notification column.
Change Your Language
At the upper right, click your user icon > Language, and then select a language.
Change the Theme to Dark or Light Mode
To change the theme from light mode to dark mode, at the upper right, click your profile picture > Dark mode.
Figure 1.36 Change the Theme
Change the Theme
