DRAFT help
Predictive and Specialized Modeling > Association Analysis > Association Analysis Platform Options
Publication date: 01/13/2026
Image shown hereAssociation Analysis Platform Options
The Association Analysis red triangle menu contains the following options:
Transaction Listing
Shows or hides a table listing each Transaction ID value and the items included in that transaction. The table is sorted by the Transaction ID column.
Frequent Item Sets
Shows or hides a list of item sets whose support exceeds the Minimum Support value specified in the launch window. See Frequent Item Sets.
Rules
Shows or hides a table of association rules that meet the Minimum Support, Minimum Confidence, Minimum Lift, Maximum Antecedents, and Maximum Rule Size requirements specified in the launch window. See Rules.
SVD
Shows or hides a report of a partial singular value decomposition (SVD) of the incidence matrix for the items. This decomposition reduces the incidence matrix into a user-specified number of dimensions for analysis. The SVD report also contains options to visualize the singular vectors, cluster transactions and items, save out singular vectors, and perform a rotated SVD analysis. See Overview of Singular Value Decomposition.
See “Local Data Filters in JMP Reports”, “Redo Menus in JMP Reports”, “Group Platform”, and “Save Script Menus in JMP Reports” in Using JMP for more information about the following options:
Local Data Filter
Redo
Platform Preferences
Save Script
