DRAFT help
Discovering JMP > Special Features > Automatically Update Analyses and Graphs
Publication date: 01/13/2026
When you make a change to a JMP data table, you can use the Automatic Recalc option to automatically update analyses and graphs that are associated with the data table. For example, if you exclude, include, or delete values in the data table, that change is instantly reflected in the associated analyses or graphs. Note the following information:
Some platforms do not support Automatic Recalc. See “Automatic Recalc” in Using JMP.
For the supported platforms in the Analyze menu, Automatic Recalc is turned off by default. However, for the supported platforms in the Quality and Process menu, Automatic Recalc is turned on by default, except for the Variability/Attribute Gauge Chart, Capability, and Control Chart.
For the supported platforms in the Graph menu, Automatic Recalc is turned on by default.
