DRAFT help
Essential Graphing > Cell Plots > Cell Plot Platform Options
Publication date: 01/13/2026
The Cell Plot red triangle provides the following options:
Legend
Shows or hides a legend.
Arrange Plots
Specifies how many plots to put on the same row before starting the next row of plots. This option is available only if you specify an X, Grouping variable.
See “Local Data Filters in JMP Reports”, “Redo Menus in JMP Reports”, “Group Platform”, and “Save Script Menus in JMP Reports” in Using JMP for more information about the following options:
Local Data Filter
Redo
Platform Preferences
Save Script
