DRAFT help
Publication date: 01/13/2026
Design Role
In designed experiments and in more general models, factors can behave in various ways. JMP uses the design role column property to describe these behaviors. The possible design roles include the following roles:
Continuous
Discrete Numeric
Categorical
Blocking
Covariate
Mixture
Constant
Uncontrolled
Random Block
Signal
Noise
In many of the JMP DOE platforms, you can specify factors with different design roles. In some platforms, your design requirements cause JMP to define factors. For example, Whole Plots and Subplots are factors that JMP creates when you specify very-hard-to-change and hard-to-change factors. In platforms where various design roles can occur, when JMP creates the design table for your design, each factor is assigned the Design Role column property.
For descriptions of the design roles other than Random Block, Signal, and Noise, see “Factor Types”.
For a description of the Random Block design role, see “Changes and Random Blocks”.
For descriptions of the Signal and Noise design roles, see “Factors”.
