DRAFT help
Publication date: 01/13/2026
Effect Screening
In the Fit Least Squares report, the Effect Screening options in the Response red triangle menu are useful when classical tests for effects are not available. This happens with screening designs, which often provide no degrees of freedom for error.
For these designs, most inferences about effect sizes assume that the estimates for non-intercept parameters are uncorrelated and have equal variances. These assumptions hold for the models associated with many classical experimental designs. However, there are situations where these assumptions do not hold. In both of these situations, the Effect Screening option guides you in determining which effects are significant.
The Effect Screening option uses the principle of effect sparsity (Box and Meyer 1986). This principle asserts that relatively few of the effects that you study in a screening design are active. Most are inactive, meaning that their true effects are zero and that their estimates are random error.
This section contains information about the output of some of these options.
Scaled Estimates and the Coding of Continuous Terms
Effect Screening Plot Options
Normal Plot Report
Bayes Plot Report
Pareto Plot Report
