DRAFT help
Using JMP > Enter and Edit Your Data > Enter Data in Data Tables > Enter Cell Formulas into Data Table Columns
Publication date: 01/13/2026
In numeric data table columns, you can enter cell expressions that are preceded by an equal sign =. JMP evaluates the expression and stores the new number as the cell’s value. Unlike column formulas, a cell expression is not stored. Cell expressions can contain operators, constants, and global and column variables.
To enter an expression
1. Click the cell where you want to enter the expression.
2. Type an equal sign =, and then enter the expression (Table 4.1).
3. Press Enter.
Table 4.1 Examples of Expressions in Table Cells
Example Expression
Cell Value
=sqrt(2)
1.41
=456+890
1346
=height+weight
Sums the values of cells in columns height and weight that are located in the same row as the cell where you entered the expression.
=height[1]
Displays the value that is found in row 1 of the height column.
