DRAFT help
Essential Graphing > Contour Plots > Example of a Contour Plot
Publication date: 01/13/2026
To create a contour plot, you can use either the Contour platform or Graph Builder. This section provides examples for both.
To see the Contour platform example, see Example That Uses the Contour Platform.
To see the Graph Builder example, see Example of a Contour Plot in Graph Builder.
