DRAFT help
Predictive and Specialized Modeling > Explore Missing Values > Explore Missing Values Platform Options
Publication date: 01/13/2026
The Explore Missing Values red triangle menu contains the following options:
ADI Loading Matrix
(Available only for the ADI method.) Shows or hides a report that contains the columns that correspond to the factor loading for each component.
For more information about the following options, see “Redo Menus in JMP Reports”, “Group Platform”, and “Save Script Menus in JMP Reports” in Using JMP:
Redo
Platform Preferences
Save Script
Note: Additional options for this platform are available through scripting. Select Help > Scripting Index. In the Scripting Index, you can also find examples for scripting the options that are described in this section.
