DRAFT help
Publication date: 01/13/2026
Image shown hereFunctional Data Explorer Group Options
Functional Data Explorer Group options are available only when there are multiple functional processes specified in the Stacked Data Format tab in the launch window.
Summaries
A submenu of options to show or hide plots of functional summary statistics for all functional processes. See Summaries.
Data Processing
A submenu of data processing options that can be applied to all functional processes. See Data Processing Options.
Models
A submenu of model options that can be fit to all functional processes. See Models.
Save Data
Saves the processed data for all functional processes to a new data table. The processed data are saved in the stacked data format.
Save Summaries
Saves the summary statistics specified in each Function Summaries report to a new data table. The name of the new data table describes the model fit. This data table contains formula columns for the eigenfunctions, mean function, prediction function, and conditional prediction function for each of the Y variables. In the data table, there is a profiler script for each Y variable that launches the prediction profilers for the prediction and conditional prediction formulas. These formulas are functions of the input variable, the ID variable, and the eigenfunctions.
Arrange in Rows
Specifies how many reports are displayed across the window.
See “Local Data Filters in JMP Reports”, “Redo Menus in JMP Reports”, “Group Platform”, and “Save Script Menus in JMP Reports” in Using JMP for more information about the following options:
Local Data Filter
Redo
Platform Preferences
Save Script
