DRAFT help
Life Sciences > Marker Simulation > The Marker Simulation Report and Options > Generation Diversity Evaluation Plots
Publication date: 01/13/2026
These plots show how the measures of diversity compare and trend across generations.
Note: You must select the Estimate Diversity check box to view these plots. These plots are not shown when the simulation is run for one generation only or when the total number of crosses exceeds the specified display threshold.
