DRAFT help
Life Sciences > Marker Simulation
Publication date: 01/13/2026
Image shown hereMarker Simulation
The Marker Simulation platform simulates the progeny from a specified set of crosses by using biallelic markers and predictor formulas (predictive models that are generated by using the Response Screening platform, see “Response Screening” in Predictive and Specialized Modeling) that are saved in your data table. This process enables you to test various crosses to estimate which crosses generate progeny with the wanted trait combinations.
Note: Specifying a large number of crosses, progeny, or both can consume considerable CPU and disk resources.
Figure 4.1 Example of the Marker Simulation Platform
Note: The Marker Simulation platform is available only in JMP Pro.
Contents
Example of Marker Simulation
Launch the Marker Simulation Platform
Required Data Format for the Marker Simulation Platform
The Marker Simulation Report and Options
Summary of Simulation
Generation Evaluation Table
Scatterplot Matrix
Generation Trait Evaluation Plot
Generation Diversity Evaluation Plots
