DRAFT help
Discovering JMP > Introducing JMP
Publication date: 01/13/2026
Introducing JMP
Basic Concepts
JMP (pronounced jump) is a powerful and interactive data visualization and statistical analysis tool. Use JMP to learn more about your data by performing analyses and interacting with the data by using data tables, graphs, charts, and reports.
With JMP, you do not have to be an expert in statistics to get insights from your data. Researchers can perform a wide range of statistical analyses and modeling, while business analysts can quickly uncover trends and patterns.
For example, you can use JMP to do the following tasks:
Create interactive graphs and charts to explore your data and discover relationships.
Discover patterns of variation across many variables at once.
Explore and summarize large amounts of data.
Develop powerful statistical models to predict the future.
Figure 2.1 Examples of JMP Reports
Contents
JMP Concepts That You Should Know
Get Started with JMP
JMP Basics
Sample Data
Understand Data Tables
Understand the JMP Workflow
Step 1: Perform the Analysis and View Results
Step 2: Remove the Box Plot from a JMP Report
Step 3: Request Additional JMP Output
Step 4: Interact with JMP Platform Results
How JMP Differs from Excel
Structure of a Data Table
Formulas in JMP
JMP Analysis and Graphing
