DRAFT help
Publication date: 01/13/2026
Map Shapes
In Graph Builder, the Map Shapes element Image shown here shows areas that are defined by the variable in the Map Shape zone.
When a column in your data table contains the names of geographical regions (such as countries, states, provinces, or counties), you can assign the column to the Map Shape zone. When you drop a variable in the Map Shape zone, Graph Builder searches for internal maps that correspond to the values in the column. If it finds an appropriate map, it draws the map in the graph area.
Alternatively, you can define the Map Role column property for the column of interest. This property tells JMP how to connect the values in the column with map shape data. It is especially useful when you create custom maps. See “Custom Map Files”.
If you have a variable in the Map Shape zone, the X and Y zones disappear. You can add information from other variables by using Color and Size.
To color the map shapes by the values of a summary statistic, drag the column of interest to the Color zone. The categorical or continuous color theme that is selected in your Preferences is applied to each shape.
To size the map shapes by the values of a summary statistic, drag the column of interest to the Size zone. This scales the map shapes according to the summary statistic value of the size variable, minimizing distortion.
See “Maps”. For examples, see “Additional Examples of Creating Maps” or run the associated scripts in these sample data tables: PopulationByMSA.jmp or SAT.jmp.
Figure 3.42 Map Shapes Options
Map Shapes Options
Summary Statistic
Changes the statistic that is plotted as the Color or Size variable. For more information about Summary Statistics, see “Explanation of Summary Statistics” in Using JMP.
Show Missing Shapes
Shows or hides missing data from the map.
Variables
Shows or hides graph elements for variables, or re-orders the display of variables.
Note: These options do not apply to variables in the Group X, Group Y, Wrap, or Page zones.
Check boxes are followed by the zone designation and the name of the variable. Use the check boxes to perform the following actions:
Show or hide the elements that correspond to a variable in a zone.
Add or remove the effect of applying the Color, Size, Shape, or Freq variable to the variable in the zone.
Tip: If you have multiple graphs, you can color or size each graph by different variables. Drag a second variable to the Color or Size zone and drop it in a corner. In the Variables option, select the specific color or size variable to apply to each graph.
Use arrows to re-order the display if there are multiple variables in a zone. Highlight a variable name and click an arrow to reposition it.
For an example that uses Variables, see “Example of an Area and Line Chart”.
