DRAFT help
Publication date: 01/13/2026
MATLAB Integration Functions
JMP provides the following interfaces to access MATLAB. The basic execution model is to first initialize the MATLAB connection, perform the required MATLAB operations, and then terminate the MATLAB connection. In most cases, these functions return 0 if the MATLAB operation was successful or an error code if it was not. If the MATLAB operation is not successful, a message is written to the Log window. The single exception to this is MATLAB Get( ), which returns a value.
See “Work with MATLAB” in the Scripting Guide for more information on working with MATLAB.
MATLAB JSL Function Interfaces
MATLAB Connect( <named arguments> )
Description
Initializes the MATLAB integration interfaces and returns an active MATLAB integration interface connection as a scriptable object.
Returns
MATLAB scriptable object.
Named Arguments
Echo(Boolean)
Sends the MATLAB source lines to the JMP log. The default value is true.
MATLAB Control( <named arguments> )
Description
Sends control operations to signal MATLAB with external events such as source line echoing.
Returns
None.
Arguments
None.
Named Arguments
Echo(Boolean)
Global. Echo MATLAB source lines to the JMP log.
MATLAB Execute( { list of inputs }, { list of outputs }, mCode, <named arguments> )
Description
Submits the MATLAB code to the active global MATLAB connection given a list of inputs. Upon completion, retrieves a list of outputs.
Returns
0 if successful, otherwise nonzero.
Arguments
{ list of inputs }
Positional, name list. List of JMP variable names to send to MATLAB as inputs.
{ list of outputs }
Positional, name list. List of JMP variable names to retrieve from MATLAB as outputs.
mCode
Positional, quoted string. The MATLAB code to submit.
Named Arguments
Expand(Boolean)
Perform an Eval Insert on the MATLAB code prior to submission.
Echo(Boolean)
Echo MATLAB source lines to the JMP log. Default is true.
Example
The following example sends the JMP variables x and y to MATLAB, executes the MATLAB statement z = x * y, and then gets the MATLAB variable z and returns it to JMP.
MATLAB Init();
x = [1 2 3];
y = [4 5 6];
MATLAB Execute( {x, y}, {z}, "z = x * y;" );
Show( z );
MATLAB Get( name )
Description
Gets named variable from MATLAB to JMP.
Returns
Value of named variable.
Arguments
name
Positional. The name of a JMP variable to be sent to MATLAB.
Example
Suppose that a matrix named qbx and a structure named df are present in your MATLAB connection.
// get the MATLAB variable qbx and placed it into a JMP variable qbx
qbx = MATLAB Get( qbx );
/* get the MATLAB variable df and placed it into a JMP data table
referenced by df */
df = MATLAB Get( df );
Table 2.1 shows what JMP data types can be exchanged with MATLAB using the MATLAB Get( ) function. Getting lists from MATLAB recursively examines each element of the list and sends each base MATLAB data type. Nested lists are supported.
Table 2.1 JMP and MATLAB Equivalent Data Types for MATLAB Get( )
MATLAB Data Type
JMP Data Type
Double
Numeric
Logical
Numeric ( 0 | 1 )
String
String
Integer
Numeric
Date/Time
Numeric
Structure
JSL Associative Array (map)
Matrix
Numeric Matrix
Numeric Vector
Numeric Matrix
String Vector
List of Strings
Graph
Picture object
Table
Data Table
MATLAB Get Graphics( format )
Description
Get the last graphic object written to the MATLAB graph display window in a specific graphic format. The graphic object can be returned in several graphic formats.
Returns
JMP Picture object.
Argument
format
Positional. The format the MATLAB graph display window contents are to be converted to. Valid formats are png, jpeg, svg, eps, epsc, eps2, epsc2, bmpmono, bmp16m, bmp256, tiff, tiffn, and pdf.
MATLAB Get Version
Description
Returns the version number of MATLAB being used with the JMP MATLAB interfaces.
MATLAB Init( <named arguments> )
Description
Initializes the MATLAB integration interfaces.
Returns
Return code.
Named Arguments
Echo(Boolean) Sends MATLAB source lines to the JMP log. This option is global. The default value is true.
MATLAB Is Connected()
Description
Determines whether a MATLAB connection is active.
Returns
1 if connected, otherwise 0.
MATLAB JMP Name To MATLAB Name( name )
Description
Maps a JMP variable name to its corresponding MATLAB variable name using MATLAB variable name naming rules.
Returns
A quoted string, mapped MATLAB variable name.
Argument
name
MATLAB Load( path )
Description
Loads variables into MATLAB from a .mat file and returns the variables to a JSL associative array. The name of the variable is the key and the value of the MATLAB variable is the value in the associative array.
MATLAB Send( name, <named arguments> )
Description
Sends the named variable from JMP to MATLAB.
Returns
Arguments
name
Named Arguments
The following optional arguments apply to data tables only:
Selected(Boolean)
Send selected rows from the referenced data table to MATLAB.
Excluded(Boolean)
Send only excluded rows from the referenced data table to MATLAB.
Labeled(Boolean)
Send only labeled rows from the referenced data table to MATLAB.
Hidden(Boolean)
Send only hidden rows from the referenced data table to MATLAB.
Colored(Boolean)
Send only colored rows from the referenced data table to MATLAB.
Markered(Boolean)
Send only markered rows from the referenced data table to MATLAB.
Row States(Boolean, <named arguments>)
Send row states from referenced data table to MATLAB by adding an additional data column named “RowState”. Create multiple selections by adding together individual settings. The row state consists of individual settings with the following values:
Selected = 1
Excluded = 2
Labeled = 4
Hidden = 8
Colored = 16
Markered = 32
The following optional, named Row States arguments are supported:
Colors(Boolean)
Send row colors. Adds additional data column named “RowStateColor”.
Markers(Boolean)
Send row markers. Adds additional data column named “RowStateMarker”.
Example
// create a matrix, assign it to X, and send the matrix to MATLAB
X = [1 2 3];
ml = MATLAB Send( X );
/* open a data table, assign a reference to it to dt, and send the
data table along with its current row states to MATLAB */
ml = MATLAB Send( dt, Row States( 1 ) );
Table 2.2 shows what JMP data types can be exchanged with MATLAB using the MATLAB Send( ) function. Sending lists to MATLAB recursively examines each element of the list and sends each base JMP data type. Nested lists are supported.
Table 2.2 JMP and MATLAB Equivalent Data Types for MATLAB Send( )
MATLAB Data Type
JMP Data Type
Double
Numeric
String
String
Double Matrix
Matrix
Structure
Table
Data Table
Example
MATLAB Init( );
X = 1;
MATLAB Send( X );
S = "Report Title";
MATLAB Send( S );
M = [1 2 3, 4 5 6, 7 8 9];
MATLAB Send( M );
MATLAB Submit( "
X
S
M
MATLAB Term( );
MATLAB Send File(filename, <MATLAB Name(name)>)
Description
Sends a data file to MATLAB.
Arguments
filename
Specifies a quoted string that identifies the pathname to the file to be sent to MATLAB.
MATLAB Name
Enables you to change the name of the file sent to MATLAB.
MATLAB Submit File( pathname, <named arguments> )
Description
Submits statements to MATLAB using a file pointed to by pathname.
Returns
Arguments
Pathname
Positional, quoted string. Pathname to file containing MATLAB source lines to be executed.
Named Arguments
Expand(Boolean)
Echo(Boolean)
MATLAB Submit( mCode, <named arguments> )
Description
Submits the MATLAB code to the active global MATLAB connection.
Returns
Arguments
mCode
Named Arguments
Expand(Boolean)
Echo(Boolean)
Example
The following example creates two vectors of random points and plots them as x and y variables.
MATLAB Init();
mc = MATLAB Submit("/[
	x = rand(5);
	fprintf('%f/n', x);
	y = rand(5);
	fprintf('%f/n', x);
	z = plot(x, y);
MATLAB Term();
Description
Terminates the currently active MATLAB integration interface.
Returns
1 if an active MATLAB connection exists, otherwise returns 0.
Arguments
None.
