DRAFT help
Fitting Linear Models > Mixed Models
Publication date: 01/13/2026
Image shown hereMixed Models
Jointly Model the Mean and Covariance
The Mixed Model personality of the Fit Model platform is available only in JMP Pro.
The Mixed Model personality fits a wide variety of linear models for continuous responses with complex covariance structures. These models include random coefficients, repeated measures, spatial data, and data with multiple correlated responses. Use the Mixed Model personality to specify linear mixed models and their covariance structures conveniently using an intuitive interface, and to fit these models using maximum likelihood methods.
The modeling results are supported by interactive visualization tools such as profilers, surface plots, and contour plots. You can use these tools to complement your understanding of the model.
Figure 8.1 Marginal Model Profiler for a Split Plot Experiment
Contents
Overview of the Mixed Model Personality
Example Using the Mixed Model Personality
Launch the Mixed Model Personality
Fit Model Launch Window
Data Format
Mixed Model Report and Options
Random Effects Covariance Parameter Estimates
Fixed Effects Parameter Estimates
Repeated Effects Covariance Parameter Estimates
Random Coefficients
Random Effects Predictions
Fixed Effects Tests
Sequential Tests
Multiple Comparisons
Compare Slopes
Stability Analysis
Marginal Model Inference
Actual by Predicted Plot
Residual Plots
Marginal Model Profilers
Variogram
Conditional Model Inference
Actual by Conditional Predicted Plot
Conditional Residual Plots
Conditional Profilers
Additional Examples of the Mixed Model Personality
Example of Repeated Measures
Example of a Split Plot Experiment
Example of a Uniformity Trial
Example of a Correlated Response
Statistical Details for the Mixed Model Personality
Statistical Details for the Convergence Score Test
Statistical Details for the Random Coefficient Model
Statistical Details for Repeated Measures
Statistical Details for Repeated Covariance Structures
Statistical Details for Spatial and Temporal Variability
Statistical Details for the Kackar-Harville Correction
