DRAFT help
Multivariate Methods > Multivariate Embedding > Multivariate Embedding Platform Options
Publication date: 01/13/2026
Image shown hereMultivariate Embedding Platform Options
The Multivariate Embedding red triangle menu contains the following options:
Save Embedding Components Value
Saves the derived t-SNE or UMAP components as new columns in the data table.
Show PQ Matrices
(Available only if the t-SNE method is used and the Sparse option is not selected in the launch window.) Creates two new data tables that contain the P and Q matrices used in the t-SNE computation. See Statistical Details for the t-SNE Method.
See “Local Data Filters in JMP Reports”, “Redo Menus in JMP Reports”, “Group Platform”, and “Save Script Menus in JMP Reports” in Using JMP for more information about the following options:
Local Data Filter
Redo
Platform Preferences
Save Script
