DRAFT help
Essential Graphing > Parallel Plots > Parallel Plot Platform Options
Publication date: 01/13/2026
The Parallel Plot red triangle provides the following options:
Show Reversing Checkboxes
Reverses the scale for one or more variables.
See “Local Data Filters in JMP Reports”, “Redo Menus in JMP Reports”, “Group Platform”, and “Save Script Menus in JMP Reports” in Using JMP for more information about the following options:
Local Data Filter
Redo
Platform Preferences
Save Script
For more information about the right-click menu options that appear when you right-click a parallel plot, see Using JMP.
