DRAFT help
Predictive and Specialized Modeling > Predictor Screening > Predictor Screening Platform Options
Publication date: 01/13/2026
The Predictor Screening red triangle menu has the following options:
Save Results
Creates a new data table that contains the predictor ranking table from the report.
See “Local Data Filters in JMP Reports”, “Redo Menus in JMP Reports”, “Group Platform”, and “Save Script Menus in JMP Reports” in Using JMP for more information about the following options:
Local Data Filter
Redo
Platform Preferences
Save Script
