DRAFT help
Publication date: 01/13/2026
Project Log
In a JMP Project, you can see log messages in the Log tool panel.
Tips:
To hide or show the Log tool panel, select Project > Show Log. To specify which tool panels appear by default when you create a project, select File > Preferences > Projects and choose the initial tool panels.
By default, log messages that occur in projects appear only in the project log, not in the main JMP log. To change this setting, select File > Preferences > Projects and update Use Project Log Pane to If Open or Never.
