DRAFT help
Using JMP > Save and Share Your Data > Work with Projects
Publication date: 01/13/2026
Work with Projects
If you are constantly opening the same related files and reports, saving them to a project file is a quick way to reopen and access them in one place. You can also share the project file with other JMP users.
Figure 11.21 Project File with Data Tables and Reports
This section contains the following information:
Create a New Project
Open Files in a Project
Rearrange Files in Projects
Save a Project
Project Workspace
Project Bookmarks
Project Contents
Recent Files in Projects
Project Log
Move Files into Projects
Write a Project On Open Script
Example of Creating a New Project
