DRAFT help
Publication date: 01/13/2026
Python Integration Functions
Python Connect()
Description
Returns an active Python integration interface connection as a scriptable object. Parameters that were available for Python Connect() in JMP 14-17 are deprecated.
Python Create JPIP CMD()
Description
Triggers the creation of a jpip command line wrapper script for Python’s pip command. A directory picker dialog will ask for the directory location to save the generated script. This script then provides the full capabilities of pip, while correctly establishing the necessary environment variables for JMP’s isolated Python environment.
Example
Names Default To Here( 1 );
Python Create JPIP CMD();
Python Disconnect()
This function is deprecated.
Python Execute({list of inputs}, {list of outputs}, Python_Code)
Description
Submits Python code to the Python environment given a list of inputs. On completion, the outputs are returned in the output list.
Returns
Returns 0 if successful and 1 otherwise.
Arguments
{list of inputs}
A list of JMP variable names to be sent to Python as inputs.
{list of outputs}
A list of JMP variable names to be retrieved from Python as outputs.
Python_Code
The Python code to submit.
Examples
This example sends a character variable, a numeric variable, and a set of matrices to Python. Python is then instructed to perform a set of matrix operations on the sent matrices. The Python Execute() function then gets the set of matrices created by the matrix operations and gets the values of the character and numeric variables that was originally sent.
a = "abcdef";
d = 3.141;
x = 0;
z = 0;
v = [1 0 0, 0 1 0, 0 0 1];
// pi, e, phi, c, Plank's, Faraday, 345 triangle
m = [3.141 2.718 1.618,
2.997 6.626 9.648,
3 4 5];
ml = Python Execute(
	{v, m, a, d},
	{x, z, a, d},
import numpy as np
a = np.multiply(v, m) # matrix product
d = np.divide(v, m) # matrix division
z = np.multiply(m, np.linalg.inv(v)) # m * inv(v) called Left division
x = np.multiply(np.linalg.inv(m), v) # inv(m) * v called right division
Show( v, m, ml, x, z, a, d );
v =
[ 1 0 0,
0 1 0,
0 0 1];
m =
[ 3.141 2.718 1.618,
2.997 6.626 9.648,
3 4 5];
ml = 0;
x =
[ -0.681183278459541 0 0,
0 1.3532624962586 0,
0 0 1.57966926070039];
z =
[ 3.141 0 0,
0 6.626 0,
0 0 5];
a =
[ 3.141 0 0,
0 6.626 0,
0 0 5];
d =
[ 0.318369945877109 0 0,
0 0.150920615756112 0,
0 0 0.2];
Python Get(python_var)
Description
Gets a named variable from Python.
Returns
The value of the named variable.
Argument
name
The name of the Python variable to be sent to JMP. The argument can represent any of the following Python data types: numeric, quoted string, matrix, list, or data frame.
Example
x1 = {1, 2, 3};
Python Send( x1 );
x2 = Python Get( x1 );
Show( x1, x2 );
x1 = {1, 2, 3};
x2 = {1, 2, 3};
Python Get Graphics(format)
Description
This function is deprecated and will generate a syntax error when used. Previously, the function returned the last graphics object written by matplotlib’s pyplot in a graphics format specified by the format argument.
Example
The following example shows the previous method commented out and the new alternative.
ml = Python Submit(
# This sample requires the matplotlib package to be installed.
import matplotlib.pyplot as plt
plt.clf()         # make sure we are starting with a clean plot
plt.plot([1, 2, 3, 4])
plt.ylabel('some numbers')
plt.draw()
# Save image to location of your choosing
plt.savefig('/tmp/get_graphics_img.png')
// plot = Python Get Graphics( png );       // DEPRECATED
plot = Open( "/tmp/get_graphics_img.png", png );
pngJMP = New Window( "Plot", Picture Box( plot ) );
Python Submit( "plt.close()" );
rc = Delete File( "/tmp/get_graphics_img.png" );
Python Get Version()
Description
Returns the version number of Python being used with the JMP Python interfaces.
Python Init()
This function is deprecated as of JMP 18. Instead, use Python Connect().
Python Install Packages(packages)
Description
This wrappers the install of Python packages into the JMP site-packages directory. For operations beyond simple package installation, use Python Create JPIP CMD() to create a command line wrapper script in a directory chosen with Directory Pick(). Alternatively, to run the install from a JMP Python script window, see “Install Python Packages in JMP’s Python Environment” in the JMP Scripting Guide.
Example
// Install numpy and pandas packages
Python Install Packages( "numpy pandas" );
Python Is Connected
This function is deprecated and always returns 1.
Python JMP Name to Python Name(jmp_var)
Description
Maps a JMP variable name to its corresponding Python variable name using Python variable name naming rules.
Returns
A quoted string, the mapped Python name.
Argument
jmp_var
The name of the JMP variable to be sent to Python.
Python Reset()
Description
Resets the shared Python environment, clearing all references to objects. A reset does not change the import cache of imported modules. This is a limitation of the Python environment itself: modules that load shared libraries cannot be unloaded by the running process. To reload pure Python code, see the Python.org documentation on importlib reload().
Python Send(jmp_var, <Python Name( name ) | "as_name" >)
Description
Sends a named variable from JMP to Python. Data table columns can be passed as the variable.
Returns
0 if successful.
Arguments
jmp_var
<Python Name( name )>
Specifies the name assigned to the variable in the Python environment.
as_name
The name assigned to the variable in the Python environment. The name is automatically passed through Python Name() to ensure a valid Python variable name.
Examples
Assuming ‘Big Class.jmp’ as variable dt, the following code creates a vector named ‘weight’ that has the values from the data table’s weight column:
Python Send( dt:weight );
This example sends data to Python:
x = {1, 2, 3};
Python Send( x );
Python Send( dt );
Python Submit( "print(x)" );
Python Submit( "print(dt)" );
Python Send File(filename, <Python Name( name )>)
Description
Sends a data file to Python. The file name argument is a quoted string that specifies a pathname to the file to be sent to Python.
Argument
filename
The name of the file to be sent to Python.
Specifies the name assigned to the file in the Python environment.
Python Submit(python_code)
Description
Submits Python code to the Python environment.
Returns
Returns 0 if successful and non-zero otherwise.
Arguments
python_code
The Python code to submit. Statements can be a quoted string value or a list of string values.
Example
Python Submit( "\[
str = 'The quick brown fox jumps over the lazy dog'
a = 200]\" );
getStr = Python Get( str );
getNum = Python Get( a );
Show( getStr, getNum );
getStr = "The quick brown fox jumps over the lazy dog";
getNum = 200;
Python Submit File(path)
Description
Submits statements to Python using the file specified in the path name.
Argument
path
The path to the file that contains the Python source lines to be executed.
Python Term()
