DRAFT help
Quality and Process Methods > Process Capability > Statistical Details for the Process Capability Platform > Statistical Details for Capability Indices for Normal Distributions
Publication date: 01/13/2026
This section provides details about the calculation of capability indices for normal data in the Process Capability platform.
For a process characteristic with mean μ and standard deviation σ, the population-based capability indices are defined as follows. For sample observations, the parameters are replaced by their estimates:
Cp = Equation shown here
Cpl = Equation shown here
Cpu = Equation shown here
Cpk = Equation shown here
Cpm = Equation shown here
Target Index = Equation shown here
The formulas use the following notation:
LSL = Lower specification limit
USL = Upper specification limit
T = Target value
N is the number of observations
m is the number of subgroups
For estimates of Within Sigma capability, σ is estimated using the subgrouping method that you specified. For estimates of Overall Sigma capability, σ is estimated using the sample standard deviation. If either of the specification limits is missing, the capability indices containing the missing specification limit are reported as missing.
Note: With the default AIAG (Ppk) Labeling, the indices based on Overall Sigma are denoted by Pp, Ppl, Ppu, and Ppk. The labeling for the index Cpm does not change when Overall Sigma is used. The formulas in this section are defined using Cp labels.
Within Capability Degrees of Freedom
For Within Sigma capability, the degrees of freedom calculation depends on the subgrouping and the within sigma estimation method.
For Within Sigma capability with unbalanced subgroups, the degrees of freedom calculation is the same regardless of the within sigma estimation method. The degrees of freedom is equal to N - m.
For Within Sigma capability with balanced subgroups of size n = N/m, the degrees of freedom calculation depends on the within sigma estimation method.
When Within Sigma is estimated by the average of the unbiased standard deviations, the degrees of freedom is equal to f * (N - m). The scale factor f, which varies between 0.875 and 1, is defined as follows:
Equation shown here
where Γ(n) is the gamma function evaluated at n.
For more information, see Bissell (1990).
When Within Sigma is estimated by the average of ranges, the degrees of freedom is calculated as df = 1/A - (3/16) * A + (3/64) * A2 + 0.25. A is defined as follows:
Equation shown here
d2(n) is the expected value of the range of n independent normally distributed variables with unit standard deviation
d3(n) is the standard deviation of the range of n independent normally distributed variables with unit standard deviation
For more information, see David (1951).
When Within Sigma is estimated by the unbiased pooled standard deviations, the degrees of freedom is equal to N - m.
For Within Sigma capability with no subgroups, the degrees of freedom calculation depends on the within sigma estimation method.
When Within Sigma is estimated by the average moving ranges, the degrees of freedom is calculated as 0.62 * (N - 1).
When Within Sigma is estimated by the median moving ranges, the degrees of freedom is calculated as 0.32 * (N - 1).
For more information, see Wheeler (2004, p. 82).
Confidence Intervals for Capability Indices
Confidence intervals for capability indices are available only for processes with normal distributions. Confidence intervals are calculated for both Within and Overall Sigma capability and are shown in the Individual Detail Reports.
Cp
The 100(1 - α)% confidence interval for Cp is calculated as follows:
Equation shown here
where
Equation shown here is the estimated value for Cp
Equation shown here is the (α/2)th quantile of a chi-square distribution with df degrees of freedom
df is the degrees of freedom
For Overall Sigma capability, the degrees of freedom is equal to N - 1.
For Within Sigma capability, the degrees of freedom depends on the subgrouping and the within sigma estimation method. See Within Capability Degrees of Freedom.
Cpk
The 100(1 - α)% confidence interval for Cpk is calculated as follows:
Equation shown here
where
Equation shown here is the estimated value for Cpk
Equation shown here is the (1 - α/2)th quantile of a standard normal distribution
Cpm
Note: The confidence interval for Cpm is computed only when the target value is centered between the lower and upper specification limits.
The 100(1 - α)% confidence interval for Cpm is calculated as follows:
Equation shown here
where
Equation shown here
Equation shown here is the (α/2)th quantile of a chi-square distribution with γ degrees of freedom
Equation shown here
Equation shown here is the mean of the observations
T is the target value
s is the sigma estimate
For Overall Sigma capability, s is the Overall Sigma estimate. For Within Sigma capability, s is replaced by the Within Sigma estimate.
Tip: For more information about confidence intervals for Cp, Cpk, and Cpm, see Pearn and Kotz (2006).
Cpl and Cpu
Lower and upper confidence limits for Cpl and Cpu are computed using the method of Chou et al. (1990).
The 100(1 - α)% confidence limits for Cpl (denoted by CPLL and CPLU) satisfy the following equations:
Equation shown here where Equation shown here
where
tdf(δ) has a non-central t-distribution with df degrees of freedom and noncentrality parameter δ
Equation shown here is the estimated value for Cpl
For Overall Sigma capability, the degrees of freedom value is equal to N - 1.
For Within Sigma capability, the degrees of freedom value depends on the subgrouping and the within sigma estimation method. See Within Capability Degrees of Freedom.
The 100(1 - α)% confidence limits for Cpu (denoted by CPUL and CPUU) satisfy the following equations:
where
Equation shown here is the estimated value for Cpu
Z Benchmark Statistics for Normal Distributions
The following formulas are used to calculate Z Benchmark statistics for normal distributions.
Z LSL = Equation shown here
Z USL = Equation shown here
Z Bench = Equation shown here
where
P1 = Equation shown here
P2 = Equation shown here
LSL is the lower specification limit
USL is the upper specification limit
σ is the sigma value
Φ−1(·) is the quantile of a standard normal distribution
Φ(·) is the cdf of the standard normal distribution
The sigma value used is determined by the Z benchmark option selected.
The Within Sigma Z Benchmark option uses the within sigma estimate.
The Between-and-Within Sigma Z Benchmark option uses the between-and-within sigma estimate.
The Overall Sigma Z Benchmark option uses the overall sigma estimate.
