DRAFT help
Quality and Process Methods > Type 1 Gauge Analysis > The Type 1 Gauge Study Report
Publication date: 01/13/2026
The Type 1 Gauge Study report contains a Type 1 Gauge Analysis report for each measurement column that was specified in the launch window. The column name is included in the title of each analysis report. By default, each Type 1 Gauge Analysis report contains a run chart of measurements and a table of summary and capability statistics.
Run Chart
Summary and Capability Statistics Table
Run Chart
In the Type 1 Gauge Analysis report, the run chart of measurements includes horizontal lines at the reference value and upper and lower tolerances. The tolerances are based on the reference standard value (Ref), percent of tolerance value (p), and the tolerance range (Tol) and are calculated as follows:
Portion of Tolerance = Ref ± 0.5p*Tol
The Run Chart red triangle menu contains the following options:
Show Portion of Tolerance
Shows or hides the portion of tolerance lines on the run chart. If a tolerance range is given or calculated, the portion of tolerance is shown by default.
Show Reference
Shows or hides the reference value on the run chart. The reference value is shown by default.
Show Mean
Shows or hides the mean on the run chart.
In the Type 1 Gauge Analysis report, the Summary and Capability Statistics table contains statistics to determine the repeatability of the measurement system.
Note: Statistics that involve the tolerance range (Tol) are included only if a tolerance range is specified in the MSA metadata prior to the analysis.
Reference (Ref)
The reference standard value defined in the MSA metadata.
Mean
The mean of the observed measurements.
Std Dev
The standard deviation, σ, of the observed measurements.
k*Std Dev
The sigma multiplier, defined in the launch, multiplied by Std Dev.
N
The number of observed measurements.
Drift
The difference between the last observation and the first observation.
Hysteresis
The overall spread of the data, calculated as the difference between the maximum value and the minimum value.
Tolerance Range (Tol)
The tolerance range.
Ref - (p/2)*Tol
The lower portion of tolerance value that is shown on the Run Chart.
Ref + (p/2)*Tol
The upper portion of tolerance value that is shown on the Run Chart.
Cg
A measure of how well the variation of the measurements fits into the specified tolerance range. A common threshold for a good measurement system is a Cg value of 1.33 or greater. Cg is calculated as follows:
Equation shown here
Cgk
A measurement that is similar to the Cg value calculation, but also takes the bias into account. A common threshold for a good measurement system is a Cgk value of 1.33 or greater. Cgk is calculated as follows:
Equation shown here
% Var for Repeatability
The percent of the tolerance range that is consumed by kσ. Higher values indicate more measurement variability in the system. The % Var for Repeatability is calculated as follows:
% Var for Repeatability = (p/Cg) × 100
% Var for Repeatability and Bias
A measurement that is similar to the % Var for Repeatability, but also takes the bias into account. The % Var for Repeatability and Bias is calculated as follows:
% Var for Repeatability and Bias = (p/Cgk) × 100
Bias
The difference between the mean and the reference standard value.
Bias/Tol %
The percent bias value, which is calculated as follows:
Equation shown here
Resolution (Res)
The smallest resolution that your measurement device is capable of reporting.
Res/Tol %
The percent resolution value, which is calculated as follows:
Equation shown here
Summary and Capability Statistics Options
Customize Summary and Capability Statistics
Opens a window that enables you to customize the statistics that are shown in the Summary and Capability Statistics table.
