Scripting Guide > Python > JSL-to-Python Interfaces > Equivalent Data Types for Python Send()
발행일 : 03/10/2025
Table 15.1 shows what JMP data types can be exchanged with Python using the Python Send() function. Sending lists or associative arrays to Python recursively examines each element of the list or associative array and sends each base JMP data type. Nested lists and associative arrays are supported.
Table 15.1 Equivalent JMP and Python Data Types for Python Send()
JSL Data Type
Python Data Type
Boolean
Boolean
Data Table
jmp.DataTable() Object
Associative Array
Dictionary
Numeric
Float
Matrix
numpy.ndarray() Object
List
List
String
Unicode String
Note: The Python package NumPy is required to use the Python Send() and Python Get() functions with the JSL Matrix data type. See Install Python Packages using JSL.
Python Send() Example
Names Default To Here( 1 );
x = {1, 2, 3};
Python Send( x );
Python Send( dt );
Python Submit( "print(x)" );
Python Submit( "print(dt)" );
