발행일: 09/10/2026
Graphics Functions
Add Color Theme({name, <flags>, {color}, <{position}>)
Description
Creates a custom color theme that you can apply to components such as markers, data table rows, and treemaps. Add the color theme to the JMP Preferences by including Add Color Theme(...) inside Preferences().
Returns
Null.
Required Arguments
name
The quoted name of the color theme.
color
Lists of RGB values. These values define the blocks in categorical color themes and the gradients in continuous color themes. Each list of RGB values corresponds to a slider in the preferences Color Themes window.
position
An optional list of numbers between 0 and 1 with one position per color. Each position corresponds to a slider in the preferences Color Themes window. If you omit the position, the sliders are evenly spaced.
Optional Argument
flags
A flag for the Continuous or Categorical color theme list and category of color.
Continuous, <Continuous>, Sequential
Continuous, <Continuous>, Diverging
Continuous, <Continuous>, Chromatic
Categorical, <Continuous>, Sequential
Categorical, <Continuous>, Diverging
Categorical, Qualitative
Categorical, <Continuous>, Chromatic
With the default JMP color themes, Sequential colors transition from left to right or right to left. Diverging colors are lighter in the middle. Chromatic colors consist of blocks or gradients of bright color. All categories except for Qualitative can be both continuous and categorical.
If you omit the flag, the color is shown in the Continuous, Sequential and Categorical, Sequential categories.
Examples
The following example creates a continuous color theme named Blue to Purple. The color is in the Diverging category. RGB values are defined in the four lists.
Add Color Theme(
	{"Blue to Purple", {"Continuous", "Diverging"}, {{0, 0, 255},
	{57, 108, 244}, "white", {128, 0, 100}}} );
Notes
Any style except for Qualitative can be Continuous and Categorical at the same time. For example, the Cool to Warm Diverging theme is in the Continuous and Categorical theme lists. In JMP, select Preferences > Graphs to see examples.
To delete a color theme, use Remove Color Theme().
See Also
Remove Color Theme(name|{name, <flags>, {color, ...}, <{position, ...}>}>)
Arc(x1, y1, x2, y2, startAngle, endAngle)
Description
Inscribes an arc in the rectangle described by the arguments.
Returns
Null.
Arguments
x1, y1
The top left of the rectangle.
x2, y2
The bottom right of the rectangle.
The starting and ending angle in degrees, where 0 degrees is 12 o'clock and 90 degrees at 3 o’clock. The arc is drawn clockwise from startAngle to endAngle.
Notes
To align the angles to the radian values used by sin() and cos(), reverse the rotation and add the 90 degree phase shift. For example, radians = 2 * pi() * (90 - degrees) / 360.
Arrow(<pixellength>, {x1, y1}, {x2, y2})
Description
Draws an arrow from the first point to the second point. The optional first argument specifies the length of the arrow’s head lines (in pixels).
Returns
Null.
Required Arguments
{x1, y1}, {x2, y2}
Two lists of two numbers that each specify a point in the graph.
Optional Argument
pixellength
The length of the arrowhead in pixels.
Notes
The two points can also be enclosed in square brackets: Arrow(<pixellength>, [x1, x2], [y1, y2]).
Back Color(name)
Description
Sets the color used for filling the graph’s background.
Returns
Null.
Argument
name
A quoted color name or a color index (such as "red" or "3" for the color red).
Char To Path(path)
Description
Converts a path specification from a quoted string to a matrix.
Returns
A matrix.
Arguments
path
A quoted string that contains the path specification.
Circle({x, y}, radius|PixelRadius(n), <...>, <"Fill">)
Description
Draws a circle centered at {x, y} with the specified radius.
Returns
Null.
Required Arguments
{x, y}
A number that describes a point in the graph
radius
The length of the circle’s radius in relation to the vertical axis. If the vertical axis is resized, the circle is also resized.
PixelRadius(n)
The length of the circle’s radius in pixels. If the vertical axis is resized, the circle is not resized.
Optional Argument
"Fill"
A positional argument indicating that all circles defined in the function are filled with the current fill color. If "Fill" is omitted, the circle is empty.
Notes
The center point and the radius can be placed in any order. You can also add additional center point and radius arguments and draw more than one circle in one statement. One point and several radii results in a bull’s-eye. Adding another point still draws all previous circles, and then adds an additional circle with the last radius specified. This means that this code:
Graph Box(circle({20, 30}, 5, {50, 50}, 15))
results in three circles, not two. First, a circle with radius 5 is drawn at 20, 30. Second, a circle with radius 5 is drawn at 50, 50. Third, a circle with radius 15 is drawn at 50, 50.
Color To HLS(color)
Description
Converts the color argument (including any JMP color) to a list of HLS values.
Returns
A list of the hue, lightness, and saturation components of color. The values range between 0 and 1.
Argument
color
A number from the JMP color index.
Example
The output from ColorToHLS() can either be assigned to a single list variable or to a list of three scalar variables:
hls = Color To HLS( 8 );
{h, l, s} = Color To HLS( 8 );
Show( hls, h, l, s );
hls = {0.778005464480874, 0.509803921568627, 0.976};
h = 0.778005464480874;
l = 0.509803921568627;
s = 0.976;
Color To RGB(color)
Description
Converts the color argument (including any JMP color) to a list of RGB values.
Returns
A list of the red, green, and blue components of color. The values range between 0 and 1.
Argument
color
Example
The output from ColorToRGB() can either be assigned to a single list variable or to a list of three scalar variables:
rgb = Color To RGB( 8 );
{r, g, b} = Color To RGB( 8 );
Show( rgb, r, g, b );
rgb = {0.670588235294118, 0.0313725490196078, 0.988235294117647};
r = 0.670588235294118;
g = 0.0313725490196078;
b = 0.988235294117647;
Contour(xVector, yVector, zGridMatrix, zContour, <messages>)
Description
Draws contours given a grid of values.
Returns
None.
Required Arguments
xVector
The n values that describe zGridMatrix.
yVector
The m values that describe zGridMatrix.
zGridMatrix
An nxm matrix of values on some surface.
zContour
The values for the contour lines.
Optional Messages
<<zColor(color, option)
The colors to use for the contour lines.
<<"Fill"|"Fill Between"|"Fill Below"|"Fill Above"
Specifies where the contour fill appears.
<<Transparency(vector)
Specifies the transparency level of the fill in a vector.
Contour Function(zExpr, xName, yName, (z|zMatrix), < <<xGrid(min, max, incr)>, < <<yGrid(min, max, incr)>, < <<zColor(color, option)>, < <<zLabeled>, < <<"Filled">, < <<"FillBetween">, < <<"Ternary">, < <<Transparency(number|matrix))
Description
Draws sets of contour lines of the expression, a function of the two symbols. The z argument can be a single value or an index or matrix of values.
Returns
None.
Arguments
zExpr
Any expression (for example, Sine(y)+Cosine(x)).
xName, yName
The values to use in the expression.
z|zMatrix
A z-value or a matrix of z-values.
Optional Messages
<<xGrid, <<yGrid
Defines a box, beyond which the contour lines are not drawn.
<<zColor
Defines the color in which to draw the contour lines. The argument can be either a scalar or a matrix but must evaluate to numeric.
<<zLabeled
Labels the contours.
<<"Filled"
Fills the contour levels using the current fill color.
<<"FillBetween"
Fills only between adjacent contours using the current fill color. For nz contours specified, this option fills nz-1 regions for the intervals between the nz values. Using this option is recommended over using the <<Filled option.
<<"Ternary"
Clips lines to be within the ternary coordinate system inside ternary plots.
Sets the transparency level of the fill. A vector of numbers between 0 and 1 are sequenced through and cycled for the z contours. This option should be used only in conjunction with the <<FillBetween option.
Drag Line(xMatrix, yMatrix, <dragScript>, <mouseUpScript>)
Description
Draws line segments between draggable vertices at the coordinates given by the matrix arguments.
Returns
None.
Required Arguments
xMatrix
A matrix of x-coordinates.
yMatrix
A matrix of y-coordinates.
Optional Arguments
dragScript
Any valid JSL script. The script is run at drag.
mouseUpScript
Any valid JSL script. The script is run at mouseup.
Drag Marker(xMatrix, yMatrix, <dragScript>, <mouseUpScript>)
Description
Draws draggable markers at the coordinates given by the matrix arguments.
Returns
None.
Arguments
xMatrix
yMatrix
dragScript
mouseUpScript
Drag Polygon(xMatrix, yMatrix, <dragScript>, <mouseupScript>)
Description
Draws a filled polygon with draggable vertices at the coordinates given by the matrix arguments.
Returns
None.
Required Arguments
xMatrix
yMatrix
Optional Arguments
dragScript
mouseUpScript
Drag Rect(xMatrix, yMatrix, <dragScript>, <mouseupScript>)
Description
Draws a filled rectangle with draggable vertices at the first two coordinates given by the matrix arguments.
Returns
None.
Required Arguments
xMatrix
A matrix of two x-coordinates.
yMatrix
A matrix of two y-coordinates.
Optional Arguments
dragScript
mouseUpScript
Notes
xMatrix and yMatrix should each contain exactly two values. The resulting coordinate pairs should follow the rules for drawing a Rect(). The first point (given by the first value in xMatrix and the first value in yMatrix) must describe the top, left point in the rectangle. The second point (given by the second value in xMatrix and the second value in yMatrix) must describe the bottom, right point in the rectangle.
Drag Text(xMatrix, yMatrix, string, <dragScript>, <mouseUpScript>)
Description
Draws the string (or all the items if a list is specified) at the coordinates given by the matrix arguments.
Returns
None.
Arguments
xMatrix
yMatrix
string
A quoted string to be drawn in the graph.
dragScript
mouseUpScript
Fill Color(name|color|rgbList)
Description
Sets the color used for filling solid areas.
Returns
None.
Arguments
name|color|rgbList
The quoted color name, index, or list of RGB values.
Fill Pattern(name|mask|image)
Description
Sets the pattern for filled areas.
Arguments
name|mask|image
The quoted color name, matrix of values between 0 and 1, or image path.
See Also
Add Fill Patterns in the Scripting Guide
Get Color Theme Detail(name)
Description
Returns a script for the specified color theme.
Example
The following example returns the script for the JMP default color theme:
Get Color Theme Detail( "JMP Default" );
{"JMP Default", 9221, {{212, 73, 88}, {61, 174, 70}, {66, 112, 221}...}}
Get Color Theme Names(<kind>)
Description
Returns a list of all color theme names or color themes of the specified kind. The kinds include "Continuous", "Categorical", "Sequential", "Diverging", "Qualitative", or "Chromatic".
Example
The following example returns all color themes:
Get Color Theme Names();
{"Green to Black to Red", "Green to White to Red", "White to Black"...}
The following example returns the diverging color themes:
Get Color Theme Names( "diverging" );
{"Green to Black to Red", "Green to White to Red", "Blue to Gray to Red"...}
Gradient Function(zExpr, xName, yName, [zLow, zHigh], zColor([colorLow, colorHigh]), < <<xGrid(min, max, incr)>, < <<yGrid(min, max, incr)> < <<Transparency(alpha|vector))
Description
Fills a set of rectangles on a grid according to a color determined by the expression value as it crosses a range corresponding to a range of colors.
Required Arguments
zExpr
xName, yName
zLow, zHigh
A matrix of low and high values (2 to 10).
The two colors that are blended together (4 is green, 6 is orange).
Optional Messages
<<xGrid, <<yGrid
Specifies a box, beyond which the gradients are not drawn.
<<zColor
The color in which to draw the contour lines. The argument can be either a scalar or a matrix but must evaluate to numeric.
The transparency level of the fill. A vector of numbers between 0 and 1 are sequenced through and cycled for the z contours.
Example
Gradient Function(Log(a * a + b * b),
a, b, [2 10],
zColor([4, 6]));
H Line(x1, x2, y)
H Line(y)
Description
Draws a horizontal line at y across the graph. If you specify start and end points on the x-axis (x1 and x2), the line is drawn horizontally at y from x1 to x2. You can also draw multiple lines by using a matrix of values in the y argument.
H Size()
Description
Returns the horizontal size of the graphics frame in pixels.
Handle(xPos, yPos, dragScript, mouseUpScript)
Description
Places draggable marker at coordinates given by xPos, yPos. The first script is executed at drag and the second at mouseup.
Heat Color(x, < <<theme>)
Heat Color(x)
Description
Returns the JMP color that corresponds to n in the color "theme".
Returns
An integer that is a JMP color.
Required Argument
x
A value between 0 and 1.
Optional Message
theme
A quoted color theme that is supported by Cell Plot. The default value is "Blue to Gray to Red".
HLS Color(h, l, s)
HLS Color({h, l, s})
Description
Converts hue, lightness, and saturation values into a JMP color number.
Returns
An integer that is a JMP color number.
Arguments
Hue, lightness, and saturation, or a list containing the three HLS values. All values should be between 0 and 1.
In Path(x, y, (pathMatrix|pathText))
Description
Determines it the point described by x and y falls in path.
Returns
True (1) if the point (x, y) is in the given path, False(0) otherwise.
Arguments
x and y
The coordinates of a point.
pathMatrix|pathText
Either a matrix or a quoted string describing a path.
In Polygon(x, y, xMatrix, yMatrix)
In Polygon(x, y, xyPolygon)
Description
Returns 1 or 0, indicating whether the point (x, y) is inside the polygon that is defined by the xMatrix and yMatrix vector arguments.
xMatrix, yMatrix can also be combined into a two-column matrix (xyPolygon), allowing you to use three arguments instead of four. Also, x and y can be conformable vectors, and then a vector of 0s and 1s are returned based on whether each (x, y) pair is inside the polygon.
Level Color(i)
Level Color(i, n)
Level Color(i, n, <theme>)
Level Color(i, <theme>)
Description
Assigns a JMP color to categorical data in a graphic.
Returns
Required Arguments
i
An integer that is greater than or equal to 1 and less than or equal to the number of categories specified by n.
n
The number of categories.
Optional Argument
theme
A quoted color theme from the Value Color list of the Column Properties window. If not specified, the JMP Default color theme is applied.
Notes
When the second argument is a quoted character string and not n, then the second argument determines the color theme.
Line({x1, y1}, {x2, y2}, ..., <<ValueSpace(Boolean))
Line([x1, x2, ...], [y1, y2, ...], <<ValueSpace(Boolean))
Description
Draws a line between points.
Arguments
{x1, y1}, {x2, y2}|[x1, x2, ...], [y1, y2, ...]
Can be any number of lists of two points, separated by commas or a matrix of x values and a matrix of y values.
Draws lines that follow the projection when the line represents a movement of the underlying data, such as a bubble trail in a bubble plot. The Boolean value can be a constant or an expression.
Line Style(name|number)
Description
Sets the line style used to draw the graph.
Argument
n
Can be either a quoted style name or the style’s number:
– 0 or "Solid"
– 1 or "Dotted"
– 2 or "Dashed"
– 3 or "DashDot"
– 4 or "DashDotDot"
Marker(<rowState>, {x1, y1}, {x2, y2}, ...)
Marker(<rowState>, [x1, x2, ...], [y1, y2, ...})
Description
Draws one or more markers at the points described either by lists or matrices. The optional rowState argument sets the type of marker.
Marker Size(n)
Description
Sets the size used for markers.
Mousetrap(dragScript, mouseUpscript)
Description
Captures click coordinates to update graph properties. The first script is executed at drag and the second script at mouseup.
New Heat Image(matrix, <colorTheme>)
Description
Creates a heat map image based on a matrix and color theme or gradient.
Arguments
matrix
A matrix of values. The function creates a heat map that has the same dimensions as the input matrix.
colorTheme
A color theme or set of gradient properties that define the mapping of values to colors. The example below shows the use of a custom gradient.
Example
width = 256;
height = 256;
wstride = 16;
hstride = 16;
b = J( hstride, wstride, Random Normal() );
a = Transform Each( {z, {row, col}},
	J( height, width, 0 ),
	b[Floor( (row - 1) / hstride ) + 1,
	Floor( (col - 1) / wstride ) + 1]
E1 = New Heat Image(
	a,
	gradient(
		{Color Theme( "Blue To Gray To Orange" ),
		Scale Type( "Standard Deviation" ),
		Show Missing Color( "On" ),
		Reverse Gradient( 1 )}
New Window( "test", Lineup Box( E1 ) );
Normal Contour(prob, meanMatrix, stdMatrix, corrMatrix, <colorsMatrix>, <fill=x>)
Description
Draws normal probability contours for k populations and two variables.
Required Arguments
prob
A scalar or matrix of probabilities.
meanMatrix
A matrix of means of size k by 2.
stdMatrix
A matrix of standard deviations of size k by 2.
corrMatrix
A matrix of correlations of size k by 1.
Optional Arguments
colorsMatrix
Specifies the color(s) for the k contour(s). The colors must be specified as JSL colors (either JSL color integer values or return values of JSL Color functions such as RGB Color or HLS Color).
fill=x
Specifies the amount of transparency for the contour fill color.
Oval(x1, y1, x2, y2, <Fill(Boolean)>)
Oval({x1, y1}, {x2, y2}, <Fill(Boolean)>)
Description
Draws an oval inside the rectangle whose diagonal has the coordinates (x1, y1) and (x2, y2). Fill is Boolean. If Fill is 0, the oval is empty. If Fill is nonzero, the oval is filled with the current fill color. The default value for Fill is 0.
Path((pathMatrix|pathText), <Fill(Boolean)>)
Description
Draws a stroke along the given path. If a fill is specified, the interior of the path is filled with the current fill color.
Required Arguments
pathMatrix
An Nx3 matrix. If you don’t specify the path matrix, specify the path text.
pathText
A quoted string that contains SVG code.
Optional Arguments
Fill(Boolean)
Specifies whether a line is drawn (0) or the path is filled (1). The default value is 0.
Notes
A path matrix has three columns, for x and y, and a flag. The flag value for each point can be 0 for control, 1 for move, 2 for line segment, 3 for cubic Bézier segment, and any negative value to close the path.
Path To Char(path)
Description
Converts a path specification from a matrix to a quoted string.
Returns
A quoted string.
Argument
path
An Nx3 path matrix.
Notes
Pen Color(n)
Description
Sets the color used for the pen.
Pen Size(n)
Description
Sets the thickness of the pen in pixels.
Pick Color(<window title>, <name|index|RGBlist>)
Description
Creates a color picker, which enables the user to select a color to apply to graphs. The operating system color picker lets users select a predefined color or create their own color. You can also specify a default color in your script. If you omit the default color, Black is selected.
Returns
The color that the user selected in the operating system’s color picker.
Arguments
window title
The quoted title of the color picker window.
name
The name of the default JMP color.
index
The number of the default JMP color.
RGBlist
The RGB values of the default color.
See Also
Create a Color Picker in the Scripting Guide
Pie(left, top, right, bottom, startAngle, endAngle)
Description
Draws a filled pie slice. The two points describe a rectangle, within which is a virtual oval. Only the slice described by the start and end angles is drawn.
Pixel Line To(h, v)
Description
Draws a one-pixel-wide line from the current pixel location to the location given in pixel coordinates. Set the current pixel location using the Pixel Origin() and Pixel Move To() functions.
Pixel Move To(h, v)
Description
Moves the current pixel location to a new location given in pixel coordinates.
Pixel Origin(x, y)
Description
Sets the origin, in graph coordinates, for subsequent Pixel Line To() or Pixel Move To() functions.
Polygon({x1, y1}, {x2, y2}, ...)
Polygon(xMatrix, yMatrix)
Description
Draws a filled polygon defined by the listed points.
Polygon Area({x1, y1}, {x2, y2}, ...)
Polygon Area(xMatrix, yMatrix)
Description
Calculates the area of the specified polygon.
Examples
area = Polygon Area( {0, 0}, {0, 10}, {10, 10}, {10, 0} );
area = Polygon Area( [10 20 30], [10 30 20] );
Polygon Centroid({x1, y1}, {x2, y2}, ...)
Polygon Centroid(xMatrix, yMatrix)
Description
Calculates the centroid of the specified polygon.
Examples
{cx, cy} = Polygon Centroid( {0, 0}, {0, 10}, {10, 10}, {10, 0} );
centroid = Polygon Centroid( [10 20 30], [10 30 20] );
Pixel Path(h, v, (path matrix|path text), <fill=Boolean)>, <scale=n>, <orient={n, n})
Description
Draws a stroke along the given pixel-based path if the fill is 0, or paints the interior of the path if the fill is not 0.
Required Arguments
h, v
Specifies the horizontal and vertical position.
path matrix
Contains three columns for h, v, and flags for each point in the path. The flag values are 0 for control, 1 for move, 2 for line segment, 3 for cubic Bézier segment, and are negative if the point also closes the path. Each flag (one for each point) can be 0, 1, 2 or 3, (or negative, if it closes the shape).
path text
Supports SVG syntax. The path is scaled (scale) and translated about its origin according to the optional parameters (fill and orient), with the orientation specified in the axis space.
Optional Arguments
fill(Boolean)
0 fills the shape. 1 draws an empty shape.
orient
Rotates the object. For example, an orientation of {Sqrt( 2 ), Sqrt( 2 )} draws the shape on a 45-degree angle.
scale
Sizes the object. For example, a scale of 1.0 draws the shape as it is defined; a scale of 2.0 draws it twice as big; and a scale of 0.5 draws it half as big.
Pixel Text(<properties>, {h, v}, text, ...)
Description
Moves to the {h, v} pixel position and draws text that the quoted text argument specifies.
Required Arguments
h
The horizontal pixel position.
v
The vertical pixel position.
text
The quoted string to display at the start and end of the pixels.
Optional Arguments
center justified
Center justifies the text.
right justified
Right justifies the text.
erased
Omits pixels from the edges of the rectangle of text. The text is drawn over the graph content in the background color, erasing the graph within the rectangle to make the text more readable.
boxed
Displays a box around the text.
counterclockwise
Rotates the text counterclockwise.
clockwise
Rotates the text clockwise.
Rect(left, top, right, bottom, <Fill(Boolean)>)
Rect({left, top}, {right, bottom}, <Fill(Boolean)>)
Description
Draws a rectangle whose diagonal has the coordinates (left, top) and (right, bottom). Fill is Boolean. If Fill is 0, the rectangle is empty. If Fill is nonzero, the rectangle is filled with the current fill color. The default value for Fill is 0.
Description
Removes a custom color theme from the global list, either by name or by the full color theme object.
Required Arguments
name
color
The RGB values for the color.
Optional Arguments
flags
A number that represents metadata such as whether the theme is continuous or categorical. Run Get Color Theme Details("name") on the color theme and use the flag that is returned.
position
A number between 0 and 1. There is one number per color that indicates where on the gradient that color is, where 0 is the beginning and 1 is the end.
Example
Remove Color Theme( {"Yellow Blue", 0, {{255, 255, 0}, {0, 0, 255}}, {0.0, 1.0}} );
RGB Color(r, g, b)
RGB Color({r, g, b})
Description
Converts red, green, and blue values into a JMP color number.
Returns
Arguments
Red, green, and blue, or a list containing the three RGB values. All values should be between 0 and 1.
Text(<properties>, ({x, y}|{left, bottom, right, top}), text)
Description
Draws the quoted string text at the given point, either the x and y axes or the left, bottom, right, and top axes.
Properties can be any of several named arguments: Center Justified, Right Justified, Erased, Boxed, Counterclockwise, Position, and named arguments. The position, named arguments, and quoted strings can be added in any order. The position and named arguments apply to all the strings.
Text Color(n)
Description
Sets the color for text strings.
Text Font(fontName, <size>, <bold italic underline strikeout>, <angle>)
Description
Sets the font for text strings. Use without arguments to get the current font properties. Angle is in degrees clockwise.
Quote the font properties. To apply multiple properties, specify them together, as in "bold italic".
Text Size(n)
Description
Sets the font size in points for text strings.
Transparency(alpha)
Description
Sets the transparency of the current drawing, with alpha between 0 and 1 where 0 is clear (no drawing) and 1 is completely opaque (the default).
Notes
Not all operating systems support transparency.
V Line(x, <y1, y2>)
Description
Draws a vertical line at x across the graph. If you specify start and end points on the y-axis (y1 and y2), the line is drawn vertically at x from y1 to y2. You can also draw multiple lines by using a matrix of values in the x argument.
V Size()
Description
Returns the vertical size of the graphics frame in pixels
X Function(zExpr, yName, <Min(min), Max(max), Fill(Boolean), Inc(upper bound))
Description
Draws a plot of the function as the yName is varied over the y-axis of the graph.
X Origin()
Description
Returns the x-value for the left edge of the graphics frame.
X Range()
Description
Returns the distance from the left to right edge of the display box. For example, X Origin() + X Range() is the right edge.
X Scale(xMin, xMax)
Description
Sets the range for the horizontal scale. The default value for xMin is 0. The default value for xMax is 100.
XY Function(x(t), y(t), t, Min(min), Max(max), (Inc(bound)|Steps(min))
Description
Combines an expression of x(t) and y(t) to draw an x-y curve for the specified range of parameter t. Each time t it is varied between Min and Max, the x and y expressions are evaluated using the current value of t.
Note: Either Inc() or Steps() is needed if the default granularity misses details.
Y Function(yExpr, xName, <Min(min), Max(max), Fill(Boolean), Inc(bound)>)
Description
Draws a plot of the function as the xName is varied over the x-axis of the graph.
Y Origin()
Description
Returns the y-value for the bottom edge of the graphics frame.
Y Range()
Description
Returns the distance from the bottom to top edges of a display box. For example, Y Origin() + Y Range() is the top edge.
Y Scale(yMin, yMax)
Description
Sets the range for the vertical scale. If you do not specify a scale, it defaults to 0, 100.
