Scripting Guide > Three-Dimensional Scenes > Add Lighting, Materials, and Normal Vectors
发布日期: 03/04/2025
The following JSL methods enable you to add lighting, materials, and normal vectors to your shapes. Using these methods, models can appear shiny or light-absorbing.
• Create Light Sources
• Specify Lighting Models
• Specify Normal Vectors
• Set the Shading Model
• Set Material Properties
• Alpha Blending
• Fade Using Fog
• Example of Drawing a Spinning Cylinder
