发布日期: 03/04/2025
Advanced Classes
Classes enable you to create objects based on templates. You can use JSL to create a definition of a class. A class definition is a template, which contains definitions for member variables, methods, and functions. After you have defined a class in JSL, you can instantiate an object that has all of the characteristics defined in the class definition.
Use the JSL function Define Class() to create a JSL class definition. Use the JSL function New Object() to instantiate an instance of a JSL class.
The JSL function Define Class() has a number of arguments that define the contents of the class:
Define Class( "class name",
	<Base Class( "base class name", <"base class name", ...> ),>
	<Show( All( Boolean ) ) | Show( <Members( Boolean ),> <Methods( Boolean ),> <Functions( Boolean )> ),>
	<Assignment Statements>
Where:
• "class name" is the name of the class being defined.
• "base class name" is one or more class names that make the set of base classes that are used as the foundation of the class being created.
• Show defines the value that appears when a class object is written out using the Show(), Print(), or Write() functions. Options include:
– All( Boolean ) shows all members, methods, and functions defined in a class object instance. The default value for All is true. If you specify the All option, that setting overrides any other arguments in the Show option.
– Members( Boolean ) shows all member variables contained in a class object instance.
– Methods( Boolean ) shows all methods contained in a class object instance.
– Functions( Boolean ) shows all functions contained in a class object instance.
Note: You can specify either the All option or any number of the Members, Methods, and Functions options, but you cannot specify both options at the same time.
Note: If a class contains a _show_ method, that method overrides the Show option.
• Assignment Statements are zero or more of the following assignment statements, separated by semicolons:
– Member = JSL Expression
– Method Name = Method( {<argument, ...>}, body )
– Function Name = Function( {<argument, ...}, {<local variable, ...>}, body )
Note: The Assignment Statements can alternatively be specified as a list of JSL expressions.
There are three specialized methods that you can use in a class definition:
_init_
Initializes the object at the time it is instantiated. This is considered the constructor for the class. You can have only one constructor per class.
_show_
Defines the output of the Show(), Print(), and Write() JSL functions when an instance of the class is used as the argument.
_to string_
Defines the output of the Char() JSL function when an instance of the class is used as the argument.
Notes:
• All methods, member variables, and functions are public.
• Functions defined within a class cannot access method variables or methods within the class.
Example of Defining a Class
The following example defines a simple class for a pet, containing the following information: name, breed, and color.
In this example, you define the constructor to require all information to create a new Pet object. Also, you define a set of accessor methods to obtain each of the attributes of a Pet object.
Define Class( "Pet",
	name = ""; breed = ""; color = "";
	_init_ = Method( { name, breed, color },
		this:name = name;
		this:color = color;
		this:breed = breed;
	_show_ = Method( {},
		Return( name || " is a " || color || " " || breed || "." )
	Get Pet Name = Method( {}, Return( name ) )
Instantiating a Class
To instantiate an instance of a JSL class object, use New Object() JSL function with any of the following functions and arguments:
New Object( "Class Name"( constructor arguments ) );
New Object( Class Name( constructor arguments ) );
New Object( Class Reference( constructor arguments ) );
New Object( "Class Name", { constructor arguments } );
New Object( Class Name, { constructor arguments } );
New Object( Class Reference, { constructor arguments } );
Examples of Instantiating and Using a Class
The following example shows how to instantiate a class to create and access JSL class objects.
class = "Pet";
xa = New Object( Pet( "Oliver", "Schnauzer", "Black" ) );
xb = New Object( class, { "Flynn", "Cockapoo", "Brown" } );
xc = New Object( class( "Mandi", "King Charles Cavalier", "Ruby" ) );
xd = New Object( "Pet"( "Charlie", "Asian", "White" ) );
xd1 = New Object( xd( "Fred", "Siamese", "Silver" ) );
xd2 = New Object( xd, { "Sam", "German Shepard", "Black and White" } );
Show( xa );
Show( xb );
Show( xc );
Show( xd );
Show( xd1 );
Show( xd2 );
xd2 = xd;                 // returns a second reference to xd
xdclone = xd << Clone;    // copy xd to a new instance, named xdclone
xd2:name = "Jerry";
Show( xd:Get Pet Name(), xd2:Get Pet Name(), xdclone:Get Pet Name() );
This example creates multiple instances of the Pet class. The output of the Show() JSL function is determined by the _show_ method that is defined in the Pet class definition. This example also illustrates the difference between creating a second JSL reference to a class instance and cloning a class instance. When using the Clone message, you are creating a new class instance that is independent of the original. However, the new instance starts out as a copy of the original.
