发布日期: 03/04/2025
Boolean Values
A Boolean value enables or disables an option. To enable the option, use 1, true, or yes as the argument.
obj << Unequal Variances( 1 );
obj << Unequal Variances( "true" );
obj << Unequal Variances( "yes" );
Note: Quoting the value prevents it from being evaluated as a variable.
Omitting the argument also enables the option. This is the default for all but row state messages.
obj << Unequal Variances;
obj << Unequal Variances();
To disable the option, use 0, false, or no as the argument.
To toggle an option (turn off an enabled option or turn on a disabled option), use "toggle".
Notes:
• The quoted "present", "absent", "on", "off", "switch", and "flip" are supported for backwards compatibility.
• For row state messages, an empty argument always toggles the option.
