发布日期: 03/04/2025
Distribution Scripts
You can use JSL to send messages to specific fits in a Distribution report or set specification limits.
Send Messages to Specific Distribution Fits
The following message for a Distribution object is available only in JSL. The message creates an array of handles to the fitted distributions, so you can send commands to specific distributions:
dist_object << ( Fit Handle[n] << ...);
You can also get a reference to a fitted distribution directly if you send the Fit Distribution message to a Distribution object. This enables you to send commands to specific distributions:
fit_object = dist_object << Fit Distribution( distribution_name );
fit_object << ...;
Set Specification Limits in Distribution Scripts
You can set specification limits using the Spec Limits column property or using the Spec Limits argument in JSL:
dt = Open( "$SAMPLE_DATA/Cities.jmp" );
dt << Distribution(
	Column( :OZONE ),
	Fit Distribution(
		Weibull(
			Spec Limits( LSL( 0.075 ), Target( 0.15 ), USL( 0.25 ) )
To set specification limits using K Sigma normal probabilities, use the Set Spec Limits for KSigma message. The first argument to the message is the value of K Sigma. By default, the limits are two-sided. To make them one-sided, use the optional sided argument. Specify sided=1 for LSL only and sided=2 for USL only.
obj = Distribution( Column( :CO ) );
obj << Fit Distribution(
	LogNormal( Set Spec Limits for KSigma( 3 ) )
