Scripting Guide > Python > The jmp Package for Python > Using the Help Function
发布日期: 03/04/2025
In Python, help() is a built-in function that provides information about packages, objects, properties, and functions as output to the log. You can use help() with the jmp package, providing a useful way to learn more about jmp package objects, functions, and more without leaving the Python environment.
In this example, help() is used to get information about the jmp.DataTable.name property.
help(jmp.DataTable.name)
Help on getset descriptor jmp.DataTable.name:
name
Data table name. [in/out]
