After you right-click a column in a report and select Bootstrap, the Bootstrapping window appears with the following options:
If Fractional Weights is not selected, the following observations are true:
If Fractional Weights is selected, the following observations are true:
In both cases, the sum of the weights is n (the number of observations in the original data).
Splits a stacked column of bootstrap results into separate columns, one for each statistic. For example, say that the column that you right-clicked before choosing Bootstrap has three statistics in it. In addition to the main results table with all the statistics stacked, another results table is created with the results for that column, unstacked into separate columns. For an example, see Stacked Results Table.
(Applicable only if the Split Selected Column option is selected) If the Split Selected Column operation is successful, the stacked results table is not shown. Only the unstacked results table appears.
