The initial results of a bootstrap analysis appear in a stacked results table (Stacked Results Table). This table may not appear if you have selected the Discard Stacked Table if Split Works option.
The BootID• column identifies the iteration of the bootstrap process. The rows where BootID• = 0 correspond to the original estimates. Those rows are marked with an X and have the excluded row state.
If you selected the Split Selected Column option, an unstacked results table may also appear. See Unstacked Results Table.
