You can create a custom shape using JSL. The Custom option opens the custom shape. If no custom shape has been created, the Custom option uses the default circle shape. For more information about creating custom shapes, see the Scripting Guide.
Shows the past history of bubbles as a semi-transparent trail. See Example of Specifying Only a Time Variable.
Shows the past history of bubbles as connected line segments. See Example of Specifying Only a Time Variable.
Splits all bubbles into their constituent parts. Unlike the Split button, the bubbles do not have to be selected.
This option appears only if you have specified two ID variables.
Combines all constituent bubbles within a group into their larger bubble. Unlike the Combine button, the bubbles do not have to be selected.
Alters how the X, Y, and Sizes roles are computed. By default, the values are calculated using means for X and Y, and sums for Sizes.
Using the Show Roles option in the red triangle menu, you can make changes to your existing variables without having to relaunch the platform and start your analysis over.
Follow the instructions in Example of a Dynamic Bubble Plot to produce the report window shown in Example of Bubble Plot with Show Roles Selected.
To change the variable assigned to a role, click on a blue underlined role name. For example, in Example of Bubble Plot with Show Roles Selected, to change the Coloring variable from Region to Country, proceed as follows:
Click OK.
Country now replaces Region as the Coloring variable in the bubble plot.
To remove an existing variable from the bubble plot, make sure that nothing is selected in the Select column for <Role> window, and click OK. For example, in Example of Bubble Plot with Show Roles Selected, to remove the Sizes variable (Pop), proceed as follows:
Click OK.
In the data table, click on the variable in the column panel, and drag it into the empty role box.
