Shows a goal plot for the data. The Goal Plot shows the spec-normalized mean shift on the x-axis, and the spec-normalized standard deviation on the y-axis for each variable. See Goal Plot for more information.
Shows a normalized box plot for the data. Each column is standardized by subtracting off the mean and dividing by the standard deviation, and quantiles are formed for each standardized column. The box plots are formed for each column from these standardized quantiles. See Normalized Box Plots for more information.
Shows a capability box plot for each variable in the analysis. The values for each column are centered by their target value and scaled by the difference between the specification limits. See Capability Box Plots for more information.
Makes a summary table for the data that includes the variable’s name, its spec-normalized mean shift, and its spec-normalized standard deviation. See Make Summary Table for more information.
Shows a capability indices report for the data showing each variable’s LSL, Target, USL, Mean, Standard Deviation, Cp, CPK, and PPM. See Capability Indices Report for more information.
Shows individual detail reports for each variable in the analysis. See Individual Detail Reports for more information.
Enables you to reorder box plots, capability indices reports, and individual details reports. You can reorder by Initial Order, Reverse Initial Order, CPK Ascending, or CPK Descending.
Normalized Box Plot shows the Normalized Box Plot for the Semiconductor Capability.jmp sample data table.
Summary Table shows the Summary Table for the Semiconductor Capability.jmp sample data table.
The Capability Indices Report option shows or hides a table showing each variable’s LSL, Target, USL, Mean, Standard Deviation, Cp, CPK, and PPM. Capability Indices shows the Capability Indices for the Semiconductor Capability.jmp sample data table. Optional columns for this report include Lower CI, Upper CI, CPM, CPL, CPU, PPM Below LSL, and PPM Above USL, among others. To reveal these optional columns, right-click on the report and select the column names from the Columns submenu.
The Individual Detail Reports option displays a capability report for each variable in the analysis. This report is identical to the one from the Distribution platform, detailed in the Basic Analysis book. Individual Detail Report shows the Individual Detail Report for PNP1 from the Semiconductor Capability.jmp sample data table.
