JMP 12 Online Documentation (English)
Discovering JMP
Using JMP
Basic Analysis
Essential Graphing
Profilers
Design of Experiments Guide
Fitting Linear Models
Specialized Models
Multivariate Methods
Quality and Process Methods
Consumer Research
Scripting Guide
JSL Syntax Reference
JMP iPad Help
JMP Interactive HTML
Capabilities Index
JMP 13.2 Online Documentation
Using JMP
Get Started
• Close Multiple Files
On Windows, close several files at once from the Window List panel on the JMP Home Window. Select the files, right-click, and select Close. Select the files, right-click, and select
Close
On Macintosh, select
File > Close Multiple
and then select the files that you want to close.
