JMP 12 Online Documentation (English)
Discovering JMP
Using JMP
Basic Analysis
Essential Graphing
Profilers
Design of Experiments Guide
Fitting Linear Models
Specialized Models
Multivariate Methods
Quality and Process Methods
Consumer Research
Scripting Guide
JSL Syntax Reference
JMP iPad Help
JMP Interactive HTML
Capabilities Index
JMP 13.2 Online Documentation
Destructive Degradation
• Destructive Degradation Platform Options
The Degradation Data Analysis red triangle menu provides the options described in
Degradation Data Analysis Platform Options
Option
Description
Graph Options
Provides options for modifying the platform graphs.
Shade
Turns the shading on or off. By default, the upper and lower bounds of each shaded band at a given value of time correspond to the 0.025 and 0.975 quantiles of the distribution of Y.
Shade Coverage
If shading is on, you can enter a proportion to increase or decrease the amount of shading coverage.
Script
Contains options that are available to all platforms. See
Using JMP
Script All By-Groups
Provides options similar to those on the Script menu. This is available if a By variable is specified.
