A tire manufacturer wants to predict an engine’s horsepower from the engine’s displacement (in3). The company is most interested in estimating the slope of the relationship between the variables. The slope values help the company predict the corresponding change in horsepower when the displacement changes.
Select Analyze > Fit Y by X.
Click OK.
6.
Select Fit Line from the Bivariate Fit red triangle menu.
7.
In the Parameter Estimates report, right-click the Estimate column and select Bootstrap (Select the Bootstrap Option).
The column that you right-click is relevant when the Split Selected Column option is selected. For more information, see Bootstrap Window Options.
8.
Type 1000 for the Number of Bootstrap Samples.
9.
Select Fractional Weights. Leave the other two options selected.
10.
Click OK.
11.
Select the unstacked results table, then select Analyze > Distribution.
12.
13.
Click OK.
