The following example uses the Coating.jmp sample data table in the Quality Control sample data folder (taken from the ASTM Manual on Presentation of Data and Control Chart Analysis). The quality characteristic of interest is the Weight column. A subgroup sample of four is chosen.
Select Analyze > Quality And Process > Control Chart > XBar.
Click OK.
Variables Charts for Coating Data
An X-chart and an R-chart for the process are shown in Variables Charts for Coating Data. Sample six indicates that the process is not in statistical control. To check the sample values, click the sample six summary point on either control chart. The corresponding rows highlight in the data table.
Note: If an S chart is chosen with the X-chart, then the limits for the X-chart are based on the standard deviation. Otherwise, the limits for the X-chart are based on the range.
X-charts display subgroup means (averages)
R-charts display subgroup ranges (maximum – minimum)
S-charts display subgroup standard deviations
The IR selection gives additional chart types:
Run charts display a column of data as a connected series of points. Run charts can also plot the group means when the Sample Label role is used, either on the window or through a script.
Moving Range charts displays moving ranges of two or more successive measurements. Moving ranges are computed for the number of consecutive measurements that you enter in the Range Span box. The default range span is 2. Because moving ranges are correlated, these charts should be interpreted with care.
Each point on a Uniformly Weighted Moving Average (UWMA) chart, also called a Moving Average chart, is the average of the w most recent subgroup means, including the present subgroup mean. When you obtain a new subgroup sample, the next moving average is computed by dropping the oldest of the previous w subgroup means and including the newest subgroup mean. The constant, w, is called the span of the moving average, and indicates how many subgroups to include to form the moving average. The larger the span (w), the smoother the UWMA line, and the less it reflects the magnitude of shifts. This means that larger values of w guard against smaller shifts.
Shows the proportion of defective items
Shows the number of defective items
Shows the average number of defective items
p-charts display the proportion of nonconforming (defective) items in subgroup samples, which can vary in size. Since each subgroup for a p-chart consists of Ni items, and an item is judged as either conforming or nonconforming, the maximum number of nonconforming items in a subgroup is Ni.
np-charts display the number of nonconforming (defective) items in subgroup samples. Because each subgroup for a np-chart consists of Ni items, and an item is judged as either conforming or nonconforming, the maximum number of nonconforming items in subgroup i is Ni.
Note: To use the Sigma column property for P- or NP- charts, the value needs to be equal to the proportion. JMP calculates the sigma as a function of the proportion and the sample sizes.
Levey-Jennings charts show a process mean with control limits based on a long-term sigma. The control limits are placed at 3s distance from the center line. The standard deviation, s, for the Levey-Jennings chart is calculated the same way standard deviation is in the Distribution platform.
