Tip: To always see reports that do not appear by default, select them using File > Preferences > Platforms > Fit Least Squares.
When there are linear dependencies among model effects, the Singularity Details report appears as the first report under the Response report title. It displays the linear functions that the model terms satisfy. These functions define the aliasing relationships among model terms. Singularity Details Report shows an example for the Singularity.jmp sample data table.
When there are linear dependencies among effects, estimates of some model terms are not unique. See Models with Linear Dependencies among Model Terms.
When an effect in a model has the response surface (&RS) or mixture response surface (&RS&Mixture) attribute, a Response Surface report is provided. See Response Surface Report for an example of a Response Surface report for the Tiretread.jmp sample data table.
If there are both positive and negative eigenvalues, the surface is saddle shaped, curving up in one direction and down in another direction. See Surface Profiler Plot with Saddle-Shaped Surface for an example using the Tiretread.jmp sample data table.
Note: The response surface report is not shown for response surface models consisting of more than 20 factors. No error message or alert is given. For more information about response surface designs, see the Design of Experiments Guide book.
For details about the REML method reports, see Restricted Maximum Likelihood (REML) Method. For details about the EMS method reports, see EMS (Traditional) Model Fit Reports.
Shows all responses in a single profiler. You can view the effects of model terms on all responses simultaneously and perform multiple optimization. See Factor Profiling.
Shows the interactive Effect Summary report that enables you to add or remove effects from the model. See Examples of Model Specifications and Their Model Fits.
Contains options that are available to all platforms. See the Using JMP book.
Shows all responses in a single profiler. You can view the effects of model terms on all responses simultaneously and perform multiple optimization. See Profiler.
Sorts the reports by significance of fit (RSquare). This option is only available for platforms that surface the RSquare to the platform level. For example, if you have hundreds of Oneway analyses generated from one launch window, they will appear in a FitGroup and you can sort them so that the strongest relationships appear first.
For details about the JMP profilers, see Profilers.
