As a JMP user, you might be given add-ins to use by co-workers. You can also find add-ins on the JMP Web site at https://www.jmp.com/addins.
Note: Developing add-ins requires experience with JMP scripting, and the process is discussed at length in the Scripting Guide.
A JMP add-in is a file that has the .jmpaddin extension. You can install it in one of two ways:
Select File > Open.
Navigate to the .jmpaddin file and select it.
Click Open.
Or, you can double-click the .jmpaddin file.
Select View > Add-Ins to see the add-ins that you have already installed.
Select View > Add-Ins.
Deselect the Enabled check box.
Select the Enabled check box.
Click Unregister.
