Recent Files: Shows recently opened files. See Recent Files.
Window List: Shows open JMP windows. See Window List.
Recent Help: Shows recently opened Help topics. Click on a topic to open it.
Note: If you close a panel and want to reopen it, select View > Home Window Panes and select the panel that you want to open.
If you re-arrange the Home Window panes and you want to return to the default layout, select View > Home Window Panes > Revert To Factory Layout.
Open the JMP Home Window by selecting View > Home Window or clicking the JMP Home Window button in the lower right corner of most JMP windows. If you cannot see the JMP Home Window button, select View > Status Bars.
Tip: If you prefer to see the JMP Starter or the Window List upon start-up, you can specify that in the Preferences (Windows only). Select File > Preferences > General and select an option from the Initial JMP Window list.
The Open Selected button opens the selected files in the Recent Files list.
The Sort By Name button sorts recent files alphabetically.
The Filter button filters the types of files that appear in the Recent Files and Window List panels.
The Clear Filter button clears any filters that are set in the Recent Files and Window List panels, showing all types of files and windows. If this button is dimmed, no filters are selected.
The New Project button creates a new project.
The Open Project button opens a project file.
The Save Selected Project button saves the selected project.
The Close button closes the panel.
To open the Window List in its own window, select View > Window List.
To always automatically display the Window List inside maximized windows, select File > Preferences > Windows Specific and select Dock the Window List in maximized windows.
In the Projects panel, you can use the project buttons to create a new project, open an existing project, and save a project. Right-click a project to add items to the project and customize the project. For details about projects, see JMP Projects (Windows Only) in Save and Share Data.
Tip: To put the Home Window back into its original order, select View > Home Window Panes > Revert to Factory Layout.
Add a recent file to the Favorites pane. Select the file in the Recent Files list, press Control, and select Add to Favorites. Select the favorite file, press Control, and select Remove from Favorites to remove the file from the list.
Open the JMP Home window on Macintosh by selecting Window > JMP Home (Example of the JMP Home Window (Macintosh)). To view the window each time you open JMP, select JMP > Preferences > General > Home Window.
If the selected window is a parent to one or more children, a dialog appears, prompting you to Close, Cancel or Close All windows. Select Close All to close the parent and all its children windows.
