End Date Variable to Use for Censoring
This option is used with modifications for the Mortality Time to Event, Progression Free Survival, and Drug-induced Liver Injury reports. Refer to the report specific descriptions below.
For Mortality Time to Event
Select which variable date reference from the demography domain to use for calculation of censored death values.
Available options are listed in the following table:
Option:
Select when you want to:
Last Disposition Record Date
• Use the last disposition record date as the cutoff date for each of the subjects.
Subject Reference End Date
• Use the reference end date (RFENDTC) as the end date. This option is selected by default.
Date of Last Study Treatment
• Use the date of the last study treatment (RFXENDTC) as the end date.
Date of End of Participation
• Use the date on which the subject left the study (RFPENDTC) as the end date.
For Progression Free Survival
Select which variable date reference to use for calculation of censored subject duration values.
Option:
Last Response Assessment Date
• Use the last date on which the subject showed a response to the treatment (RSDTC or RSDY) as the end date.This option is selected by default.
Note: Date information is typically taken from RS. If, however, there is no date information in RS, these reports merge RS and SV by USUBJID and VISIT/VISITNUM and the SV dates are used.
For Drug Induced Liver Injury
Select which variable date reference to use for censored subject duration values.
Option:
