Click Add to enter one or more linear inequality constraints.
Select factors from the Add Filter Factors list and click Add. Then specify the disallowed combinations by using the slider (for continuous factors) or by selecting levels (for categorical factors).
To remove a single factor, select Delete from its red triangle menu.
Enter the expression (Exp(X1) + 2*X2 < 0) & (X3 == 2) into the script window.
Figure 5.11 Expression in Script Editor
Help created on 10/11/2018
