a t test for the hypothesis that the estimate equals zero
Tests whether the true value of the parameter is zero. The t Ratio is the ratio of the estimate to its standard error. Given the usual assumptions about the model, the t Ratio has a Student’s t distribution under the null hypothesis.
Lists the p-value for a two-sided test of the t Ratio.
Help created on 10/11/2018
