Gives the lower 95% confidence limit for the covariance component. For more information, see Confidence Intervals for Variance Components.
Gives the upper 95% confidence limit for the covariance component. For more information, see Confidence Intervals for Variance Components.
Gives the p-value for the test that the covariance parameter is equal to zero. This column appears only when you have selected Unbounded Variance Components in the Fit Model launch window.
If Unbounded Variance Components is not selected, meaning that the parameters have a lower boundary constraint of zero, a Satterthwaite approximation is used (Satterthwaite 1946). The confidence intervals are also bounded at zero.
Random Effects Covariance Parameter Estimates
